07 civic crank no start
Old Dec 23, 2019
wmarkum98's Avatar
wmarkum98 is an unknown quantity at this point
Hey, so to sum up my problem, this past friday i had trouble starting my car but eventually it started up no problem, later that day i had an issue again with the car starting my temperature gauge never read anything over half when the car was turned off, but when i went to start it up it showed my car was running hot, now my car will crank but not start, there is a buzz sound coming from near where my left foot sits if key is slowly turned over, checked exhaust smells like gasoline and it does so it doesn't seem to be a fuel issue, I've seen a lot of videos about problems similar to mine but cant find anything that is exactly the same as mine, hoping to find some help here
Old Dec 24, 2019
GolNat's Avatar
Prelude Owner
Re: 07 civic crank no start
Check for any loose electrical connections first. How old is the battery?
Old Dec 26, 2019
Wankenstein's Avatar
Any loss of coolant? Coolant could be leaking into the cylinders via a cracked block or blown head gasket: https://community.cartalk.com/t/like...locks/120900/7 I hope that's not the issue. Check both the radiator and reservoir (when engine is cold) if it has a cap for both.
Old Dec 27, 2019
wmarkum98's Avatar
checked connections and fuses all check out, did a spark test and found out it something with the spark plugs, no spark when car is attempted to turnover, need to take apart distributor but cant find any videos for an 07 its a 1.8L anyone have something that could help? Also battery is good just not getting juice pumped back into it bc of it just sitting and cranking and not running.
Old Dec 27, 2019
wmarkum98's Avatar
its a slight loss of coolant but its not leaking into the cylinders its leaking onto the ground so theres no issue there, found out its something with the distributor (at least i hope thats all the issue is)
Old Dec 27, 2019
Colin42's Avatar
There hasn't been a distributor on a civic since 2000.......
There's a coil on top of each spark plug, if all 4 have suddenly stopped working, I would recheck the fuses maybe you missed one or didn't check them properly. No check engine light?
Old Dec 27, 2019
wmarkum98's Avatar
okay, didnt know that haha, well what do the coils run to then? do they go straight to the fuse boxes or??? And no theres not check engine light on
Old Dec 27, 2019
Colin42's Avatar
Does the check engine light work? (Comes on when you turn the key to ignition)
I'm assuming it does, that's why I'm thinking fuse, the coil pack have wires that go to the ecu and the fuse box, may want to check for damaged wires too
Old Dec 27, 2019
wmarkum98's Avatar
okay yeah ill double check the fuses and the spark plugs are getting replaced bc they are way past due
Old Dec 27, 2019
If coolant is leaking onto the ground that you can see then that is an issue. Low coolant can lead to overheating which can lead to blown headgasket. If that generation of Civic employs a closed coolant system (no radiator cap, only reservoir cap) then it should rarely, if ever need additional coolant if all parts are in working order.
The most common symptom of coolant loss in cylinders (internal leak) is coolant loss without an external leak. Also, hard starts (due to wet/coolant on spark plug) when engine is cold (especially sitting overnight) because the expansion and contraction of the block and/or head is there is a crack will leak coolant into the cylinder(s) when it the engine cools off after operating temp, and then (cracks) seals itself at operating temp. If the leak is bad enough into a cylinder there may be white smoke from the exhaust at cold start and a smell of coolant coming from exhaust. You stated no-spark is the current issue so I just listed the above for reference.
Old Dec 27, 2019
wmarkum98's Avatar
changed spark plugs and cleaned coil packs and now there's spark, so improving car cranks but wont turnover hoping to be able to jump it and hope it starts up, tried checking the fuses but have no idea which ones to check so gotta do some research any pointers for that would be fantastic
Old Dec 27, 2019
These links may help: http://honda.automotive-manuals.com/...eshooting.html and https://www.justanswer.com/honda/7qp...-no-codes.html
Old Dec 28, 2019
Colin42's Avatar
Owners manual should have fuse diagrams
Old Jan 3, 2020
Pinky_Powers's Avatar
Pinky_Powers is an unknown quantity at this point
Did you check to see if the battery had enough voltage?
5spdvroom
73
Jul 25, 2016 07:55 PM
mandan
Jun 10, 2016 09:37 PM
saadriaz
Jun 27, 2010 07:46 AM
CivicAK
Feb 8, 2010 05:52 PM
ironhide
Jan 8, 2010 03:49 PM
