2006 Civic EX - Oil in Spark Plug Tube
Old Oct 20, 2018
tb24's Avatar
tb24 is an unknown quantity at this point
First time posting here. Son's 2006 EX CEL came on - P0302 Cylinder 2 misfire. Pulled the ignition coil from cylinder 2 and found a pool of oil at the bottom of the tube. The rubber end of the coil was loose at the bottom of the tube. So ignition coil certainly bad but what would cause the oil to pool up at the bottom of the spark plug tube?
Noticed after researching this was an issue with the earlier model Civics but not on the 8th generation.
Any help or guidance would be appreciated.
Thanks!
Old Oct 24, 2018
GolNat's Avatar
Prelude Owner
Re: 2006 Civic EX - Oil in Spark Plug Tube
If it’s similar to a 7th gen it might have spark plug seals that are going bad. Easy job to do along with valve cover gasket.
Old Oct 24, 2018
Engine oil can't get into the plug tube on the 1.8 Liter R engine via valve cover gasket, it's location is not even close.
Loose spark plug might let combustion gases seep past the threads and accumulate soot and moisture in the tube
KoolBreeze
May 7, 2021 08:44 PM
Chris.benwitz
General 8th & 9th Gen
Jul 25, 2018 08:06 AM
Civicboy420
Jul 12, 2011 05:26 PM
edtech
Dec 12, 2006 09:59 AM
gearbox
Jul 19, 2006 08:20 PM
