Dashboard woes
Old Aug 11, 2005
mengsta's Avatar
mengsta is an unknown quantity at this point
Unhappy Dashboard woes
Happened quite a while back...while installing my headunit, i left an ambipur car freshener on the dash...it tripped and spilled bit of the liquid freshener on the dash ...so i quickly wiped it but it left some obvious 'gloss' mark on the dash...i tried everything to remove it but to no avail...and i dont wanna make it worse...i've tried armorall to even nail polish remover..no luck
Anyone can recommend me a dash board cleaner that might work? Would really appreciate any help
Cheers
Old Aug 11, 2005
CraigW's Avatar
Most likely it will not recover, if the material is damaged it will be won't come out
Is there any way to cover it somehow ??
Old Aug 11, 2005
mengsta's Avatar
Well it's not 'damaged' in that sense, but it's just shinier which really bugs me :P
Oh well...leave it be i guess...*sniff*
Old Aug 11, 2005
zen_master's Avatar
have you tried dish or hand soap?
use sponge to remove that residue....and then, clean with water..
Old Aug 11, 2005
mengsta's Avatar
Havent but will definitely give it a shot..will keep ya posted on the result,,
Thanx for the tip! Reallllly appreciate it.
Cheers!
Old Aug 11, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
try some mineral spirits or laquer thinner. As with any other product, try it on a hidden spot to make sure it doesnt cause more damage than good. If its ok, then one of those should get it off.
Old Aug 11, 2005
mengsta's Avatar
Tried nail polish remover at the beginning but I think it made it even more obvious :P
Soap helped a little (duh, shld have thought of that earlier!) so i soaped the whole dash and re-armoralled everything...not too bad but still a little obvious..thanx soooo much for all the suggests
Just gotta stop thinkin about the spot and maybe the pain will go away...sigh
Laters guys
Old Aug 12, 2005
ojay's Avatar
ojay is on a distinguished road
maybe try a spot treatment stain remover? then follow up with heavily diluted soap.
armor all
Old Aug 13, 2005
mengsta's Avatar
ojay, any brand suggestions for the stain remover?
Thanx
Old Aug 13, 2005
eye_see_you's Avatar
let the devil out
the armor all orage wipes have worked wonders for me try those out.
Old Aug 14, 2005
ojay's Avatar
Thanx
spray and wash. i think dow makes it? it's laundry product. let it sit and then follow it up with an APC or heavily diluted soap.
cferry7
Oct 18, 2015 06:32 PM
GritzNGravy
Aug 19, 2015 03:03 AM
BrandonD
Aug 9, 2015 10:22 AM
frisbeeguy2
Jul 30, 2015 03:00 PM
erikku
Detailing
Jul 13, 2002 01:31 AM
