Disgusting Yellow headlights
Old Feb 20, 2005
JWalker's Avatar
JWalker is an unknown quantity at this point
I was wondering if you guys had any good tips on cleaning old disgusting yellow headlights. Will i need to pop out the lights and put them in the oven to remove the lens and clean the inside? Or can I just clean the outside with some polish to make them look better? Any tips?
Old Feb 20, 2005
danase's Avatar
danase is an unknown quantity at this point
Depends if the yellowing is in the outside or inside. I use Poorboy's Polish with Carnuba or SSR1 to remove outside blemishing.
Old Feb 20, 2005
JWalker's Avatar
I just bought some I believe Blue Magic plastic and fiberglass cleaner from autozone to see if I can get any results from cleaning the outside with it.
Old Feb 20, 2005
Um I thought yellow means the plastic is damaged from the sun. I don't think there's a way to fix that. Should always wax new lights to protect from the sun.
Old Feb 20, 2005
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
u need to buff them out. find some 4' pads . they will work well with any drill. and u can use pb's ssr1 or pp
Old Feb 20, 2005
JWalker's Avatar
Hey rice you mean I need to get a buffer and buff the outside? And do you think this plastic polish could work with just a rag and some elbow grease?
Old Feb 21, 2005
civicrice's Avatar
it might work if you rub it for a while. Try sanding it also if you cant get it all out. Use 1500 grit
Old Feb 22, 2005
MeguiarsEM's Avatar
MeguiarsEM is an unknown quantity at this point
Use this to remove the yellowing....
Then use this to restore optical clarity.
Old Feb 22, 2005
JWalker's Avatar
Thanks alot meg's, I looked for some type of plastic cleaning solution by meguiars at my local autozone because I have always been loyal to meguiars for all of my waxing needs. But all I came out with was a plastic glaze of a different brand so it looks like I'll be wetsanding and/or using metal polish because I have heard that works.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
