SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
The ultimate DX/LX vs EX header/exhaust DIY and FAQ
Old Feb 22, 2009
  #181
TRIZ's Avatar
Re: The ultimate DX/LX header/exhaust FAQ
You keep saying "ex head" Your ex head and lx head and dx head all have the same bolt pattern, so you dont need to change the head to change the manifold that bolts to it. I think your also getting the parts mixed up a little- you cant weld a cat onto a header... well, I guess you could, but that would just be stupid and it would probably be an inch from the pavement so you couldnt run a cat back. Here is how the parts go:
Engine Head> header (exhaust manifold)> Downpipe with cat converter in it (this is one piece of pipe with flanges on either side and the cat in the center [if you cant get a hold of an OEM downpipe with cat, get the Random Tech pipe, OR get a test pipe and a universal weld-in cat], then your cat back exhaust system.
Old Feb 23, 2009
  #182
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
So OBX header > Random Tech downpipe (I think this is the right one *) > OBX catback
* http://shopping.lightningmotorsports...cat=664&page=1
Ok, that would work but I would like to avoid having the CEL on if possible, so looks like I should get a test pipe w/ a weld in cat
I'm assuming these universal cats have O2 sensor positions...right?
Anybody know any good websites for downpipes or universal cats?
Do any local places like Auto Zone or Advance Auto carry them?
What would the disadvantages of the Random Tech test pipe....besides the CEL?
Would I be able to smell the exhaust real bad?
Would it be super loud?
Old Feb 23, 2009
  #183
TRIZ's Avatar
yes
Get a test pipe and weld in an universal cat if you want, or pick up the RT pipe that already has it welded in for you and will bolt right up to your exhaust with no bullshit
you'd have to take that issue up with your test pipe. The weld in cats are just a blob of catalyst that is placed somewhere in the length of the pipe, no O2 sensors actually screw into it- there are two that need to be in the exhaust stream, one before the cat and one after.
Just search... theres bunches of websites. Search "Random tech" + the model year of your car... you'll get all your answers there.
they will sell universal cats most likely, yes
the RT pipe is not a test pipe... a test pipe is just a pipe WITHOUT a cat, the RT pipe has a cat... and with that cat, you wont need to worry about tricking your 2ndary exhaust sensor, which may or may not work and will probably give you several cels
with just a test pipe, yes... with the RT pipe, no
with a test pipe yes, with stock no, the RT will be somewhere inbetween with a health exhaust note
Hope that helped.
Old Feb 23, 2009
  #184
Mavrick272's Avatar
Yes sir, it did!
thanks again for all the help
Also it says it will illuminate the CEL and it's a not for highway use....you sure it has a cat in it?
( http://shopping.lightningmotorsports...cat=664&page=1 )
That one is made by Skunk2 and not RT
I don't think it's the right one
I assume the one I need is something like this http://shopping.lightningmotorsports...cat=457&page=2
that would work great, but I'm pretty sure the pipe diameter on my car is 2.25 inch and that one is 2.5 inch....
So will a testpipe will replace a downpipe?
This is the header I was looking at getting
http://cgi.ebay.com/ebaymotors/OBX-4...4369QQtcZphoto
Is that a downpipe I see there included, or is it the header just in two pieces to make it easier to install?
Old Feb 23, 2009
  #185
TRIZ's Avatar
That first link is for a test pipe... aka no cat.
That second link is what you need, or at least the type of product you need (did you say you had a 6th gen or 7th gen?). Here is a list of the part numbers of RT products that are downpipes with cats: http://www.randomtechnology.com/honda.html
That header is a race header, a 4-2-1, which will make it so you cant run the RT downpipe... or at least that is how it is on the 7th gen. I'm not sure exactly how your exhaust system looks on the 6th gen- get pics of the ex header and front part of the exhaust and I can tell you. But on race headers they usually bolt right up to the begining of the cat back.
Old Feb 24, 2009
  #186
Mavrick272's Avatar
Ok, I think I'm going to buy that header and the cat back
I'll order a cat if I need it, and if the header bolts directly to the catback, then so be it
thanks again for everything, Triz
Old Feb 24, 2009
  #187
TRIZ's Avatar
Yuppp.
Not that I really need it, but you should learn how to rep people on the forum.
Old Feb 24, 2009
  #188
TRIZ's Avatar
Yuppp.
Old Feb 24, 2009
  #189
Mavrick272's Avatar
ohhh I'ma rep the **** outta you dude!
how do I do it?
Old Feb 24, 2009
  #190
speedfoos's Avatar
Triz, your patience exceeds even mine.
Old Feb 24, 2009
  #191
Mavrick272's Avatar
that hurts, Speedfoos
it's not my fault I was born car-tarded!
Old Feb 24, 2009
  #192
TRIZ's Avatar
how do I do it?
Press the balance that is on ever post by other people, if you hover over it, it should say reputation... click "I approve" and type a message on why w/ ur name.
The days when I feel like I'm going to snap... I stay off the forum for a few days. Thats my secret.
Old Mar 11, 2009
  #193
amishman22's Avatar
amishman22 is on a distinguished road
cheapest place to find o2 extenders?
Old Mar 12, 2009
  #194
TRIZ's Avatar
Go to the first post of this thread and click on the links I provided.
Old Mar 12, 2009
  #195
Mavrick272's Avatar
Triz, I got the catback and header
It appears that the OBX header and catback leave room for a cat. converter
I'm assuming you reccomend the Random Tech cat?
(http://shopping.lightningmotorsports...cat=457&page=2)
Old Mar 12, 2009
  #196
TRIZ's Avatar
Yeah, go with the random tech cat if you want a higher flowing downpipe and cat then the stock one and dont want to pollute the world without running one. In fact, the RT pipe will flow just as good as running catless, without the added harmful effects on the environment. Pick it up
Old Mar 13, 2009
  #197
Street Kings's Avatar
Street Kings will become famous soon enoughStreet Kings will become famous soon enough
Ah man I wish I had came to this thread b4. Just bought a whole catback exhaust which was on a EM2 EX but I have a 4dr 05 LX. Feelin sooo down
Old Mar 13, 2009
  #198
Mavrick272's Avatar
Ok, so they offer an "installation kit" with the catalytic converter
I'm assuming this is the bolts I need to install it
Also, what size 02 extender cable would be appropriate?
I'm guessing 24 inch would be plenty, but car is an LX, so they stock cat position was pretty close...
Old Mar 14, 2009
  #199
TRIZ's Avatar
The thread was here, you werent... that sucks! lol
Answer is covered in first post of this thead!
Old Mar 16, 2009
  #200
just in time's Avatar
just in time is an unknown quantity at this point
I just bought a 2008 civic ex-l 2dr. I need to change the cataylic converter, honda wants $580 my question is can i eliminate it with a pipe and connect the o2 sensors or do i need to replace it? Thank you for your help. Justin
Old Mar 16, 2009
  #201
amishman22's Avatar
depends on what state you live in. does your area require an e-check?
Old Mar 16, 2009
  #202
No, i live in florida we don't have emission testing. I will be keeping the stock muffler, and don't really want a loud exhaust. Will this be possible without the cat?
Old Mar 16, 2009
  #203
TRIZ's Avatar
If your cat failed, then take it to honda- it has an extended warranty and should be replaced for free.
Old Mar 16, 2009
  #204
Yea bro, but no worries I had the muffler shop custom do it without messing up with my headers or censors. So I'm running the new catback perfectly!
Old Apr 5, 2009
  #205
Mavrick272's Avatar
Triz - got the header, cat and catback on.
It went pretty well, BUT there was about an inch and a half gap I had fudge
This fudging caused the S-shaped section of the cat-back to be planted firmly against a chunk of the frame, causing it to be quite loud as you'd imagine.
I need some advice
What are my options here?
is there a some kind of spacer avaliable for it?
I'm thinking taking it to a muffler shop and having them weld a piece into my midpipe to make it longer is going to be my best bet
Old Apr 6, 2009
  #206
TRIZ's Avatar
Yeah that might be the best idea... Can you tell where the problem is? Look for if any of the exhaust hangers dont hang directly inline with those welded on your car, this will be pretty obvious and give you a good idea of where the problem starts. Also look to see if the bend over the control arm is a good bend and not making any contact
Old Apr 10, 2009
  #207
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
ok. I have an ex with megan headers, megan downpipe/test pipe. first I had an apexi n1 catback and it rattled when it was abour 3-4k rpm. I took off the whole cat-back and put my stock cat-back on and it still rattles at around that rpm. It seems the rattling is coming from the testpipe/down pipe. any ideas on why that is?
and if something is wrong, is there a point on running just the megan headers with stock downpipe and stock catback or even the megan headers with stock downpipe and apexi n1 catback? the rattling is kinda annoying...
Old Apr 11, 2009
  #208
amishman22's Avatar
theres probably a gap btw the header and downpipe. mine did that check it out and make sure its flush. maybe get a gasket.
Old Apr 13, 2009
  #209
Mavrick272's Avatar
I got it figured out, just took it to the local Midas muffler shop and had them weld in a flexible piece
on to the rear disc conversion!
Old Apr 13, 2009
  #210
TRIZ's Avatar
Its lose. Are you using the stock spring loaded bolts?? Those things are crap and might have snapped. If your using the stock downpipe you need that donut gasket at the top of the downpipe that creates the seal at the header connection. Also use real hardware, not those stocker spring bolts.
If thats not the problem then check the connection between the downpipe and the cat back.
If thats not the problem... then check clearance issues. The exhaust flexes because the engine flexes. So it might be hitting your sway bar or something. If you have an lx/dx sway on your car the cat will be touching, there just isnt enough room and you'll need to lose the bar and pick up an EX or RSX front sway.
Report back.
