SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
The ultimate DX/LX vs EX header/exhaust DIY and FAQ
Old Oct 26, 2008
  #151
TRIZ's Avatar
Re: The ultimate DX/LX header/exhaust FAQ
Originally Posted by ChemicalBoom
Well, I finally finished. Sounds good, but the way the Random Tech downpipe bolts onto the header leaves leaks....I guess i'll hafta get it welded. And there is a lot of rattling from the undercarraige. But im happy it's done
Did you pick up the gasket from honda... I dont know if where the header bolts to the RT downpipe if you'll need that- but I'm thinking thats whats leaking.
Old Oct 26, 2008
  #152
ChemicalBoom's Avatar
ChemicalBoom is an unknown quantity at this point
It's hard to explain, but the opening of the downpipe is fluted. Kinda like the end of a horn...
The bracket you see in the pic slides up and down...
[IMG][/IMG]
And the top of the downpipe meets the bottom of the header right here
there's no spot for a gasket that i can see, and it is just the thin metal rim from the downpipe opening touching the flat piece on the header you see there, and since it's fluted, its bigger than the actual opening (pipe diameter) The bracket bolts onto the header and kinda sandwiches them together.
Am I doing this wrong? I used everything they gave me. and it all fits well. Maybe i just need to get it welded or something.
Old Oct 27, 2008
  #153
TRIZ's Avatar
That doesnt look like its a genuine honda part... its really close, but the material just looks way different.
Old Oct 27, 2008
  #154
You talking about the header right?
Old Oct 27, 2008
  #155
TRIZ's Avatar
Yeah, the header.
Old Oct 27, 2008
  #156
Ok, I brought it to my favorite muffler shop and they put a gasket between the downpipe and header (which should have been included with the header or downpipe..oh well) and they found another leak at another junction and fixed that. Also it doesn't rattle at all now
I am so happy FINALLY!!
And here's a video...
Old Oct 28, 2008
  #157
TRIZ's Avatar
Yeah, I thought you were missing the gasket. It doesnt come with the header, its a separate part.
So... is the header non honda OEM part? It looks close, but different.
Glad to see you got that exhaust on, sounds pretty good. Whats it sound like when you stomp on it, or were you? Do some drive by's
Old Oct 28, 2008
  #158
ProjectMayhemR's Avatar
the best kind of lovin is from the oven!
ProjectMayhemR will become famous soon enough
the exhaust sounds good. A lil too quite for me but very clean. I like.
Old Oct 29, 2008
  #159
I got the header from majestic honda, so it's whatever they sell
Here's my drive by video
Its super quiet in the car, but it sounds alot louder outside
Old Jan 19, 2009
  #160
usmcdevilmp's Avatar
usmcdevilmp is an unknown quantity at this point
Originally Posted by TRIZ
Ask me your questions DX/LX header/exhaust questions!!!
This will be updated as information is needed.
First many people with DX/LX’s want to know what header will work.
First, the EX header wont bolt up to your existing stock exhaust. Second, you WILL loose your cat. Here are your header options if your cool with your peashooter exhaust and no cat:
Kamakazi – part number: ??
OBX – part number: 10-1602-3D
Will an EX header bolt up to the head of an DX/LX engine?
Yes, the bolt pattern on both the D17a1 (DX/LX) and D17a2 (EX) are the same.
Additional notes:
The DX/LX exhaust has spring loaded bolts that connect the end of the header to the rest of the exhaust system; these are kind of a pain in the butt to reach but they come off eventually.
It says the DX/LX downpipe is connected to the header with spring loaded bolts, yet my EX has that as well. Do I actually have a DX/LX? How can I tell I have an EX D17a2?
Old Jan 20, 2009
  #161
TRIZ's Avatar
Pop your hood, locate your motor, from that locate your block. Facing the exhaust side of your motor, your block will be stamped in the top left with the type of motor it is.
Here's my drive by video CLICK ME
Sounds pretty good man!
Old Jan 20, 2009
  #162
I looked, all i see is a block serial number engraved and a white sticker with a barcode. None of the numbers resemble d17a1 or 2.
Old Jan 25, 2009
  #163
__________
I'm gonna simplify it for you... does your sparkplug wire cover say vtec or honda? (Its the black plastic piece on top of your valve cover). If it says vtec its an ex.
Old Jan 29, 2009
  #164
greglock's Avatar
greglock is an unknown quantity at this point
Hello All,
I know this is the "The ultimate DX/LX header/exhaust FAQ" thread, but I could not find the answer to this simple conundrum..
I have a 1998 Civic DX sedan (4dr) 1.6L
With brand new DX header and catalytic convertor in place. How can I avoid putting on a OEM exhaust which rot out in about 5 minutes? I like the sporty Catback systems because they are stainless steel and would be better in NY where the salt the roads all the time.
I need to keep costs down and keep looking at Ebay but do not want to get stung buying something that does not fit.
The question is can it be done? If not I'll just buy the tin crap they sell at autoparts stores.
Thanks for your help!
Greg
Old Jan 29, 2009
  #165
speedfoos's Avatar
www.vrsexhaust.com
You can pick up a 2.25" stainless tubing kit for like $150-175 bucks and then either you or a muffler shop can weld it up. Cheap, easy, quality. Can't beat that.
Old Jan 31, 2009
  #166
greglock's Avatar
That sounds like a good idea, would that need a muffler box and tip?
Old Jan 31, 2009
  #167
TRIZ's Avatar
Yes unless you want it to be illegally loud.
Old Feb 22, 2009
  #168
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
I have a 1998 LX and I was looking to put an OBX header, cat, and cat back on her
If I read all this right I apparently will have to weld the cat to the OBX header
If I'm going to do this, which OBX cat should I buy?
OBX offers two
1. http://cgi.ebay.com/ebaymotors/OBX-H...5503QQtcZphoto
2. http://cgi.ebay.com/ebaymotors/OBX-H...8532QQtcZphoto
One uses the factory o2 sensor position and one doesn't
I'm assuming the cheaper one, the one that uses the factory o2 spot, is the one I need but I'm just checking
(I'm also assuming at 45 bucks that it is a test pipe and not a cat, but whatev. I don't live in California, so I think if I at least have the ILLUSION of a cat, I should be good)
thanks
Old Feb 22, 2009
  #169
Mavrick272's Avatar
OBX offers two
thanks
Old Feb 22, 2009
  #170
Mavrick272's Avatar
Woah, sorry for the double post
I dunno wtf happened there
Old Feb 22, 2009
  #171
m3Lo1523's Avatar
m3Lo1523 will become famous soon enoughm3Lo1523 will become famous soon enough
hey triz will this work ex header, ex downpipe and evo2 exhaust system? Do I still need catalytic converter? And I was also wondering how much hp and tq it put out with that kind of set up?
Thanks
Old Feb 22, 2009
  #172
speedfoos's Avatar
8000whp. You should get it.
Old Feb 22, 2009
  #173
TRIZ's Avatar
OBX offers two
thanks
Your going to want a cat, without it you'll smell your exhaust whenever you have your windows open... it gets really annoying actually, and your exhaust is much louder then you'll want it- you'll turn the wrong heads, and its illegal to run without one, so you'll have to figure something out when it comes to emissions times.
I dont trust ebay listings. There are two types of cat's- ones that are universal and need to be welded in, and others that are already in the pipe that will bolt up to your system. The later is easier, but if you got pipe skills and got a welder then either one is a good pick if you think you can do quality work.
I'm not famil with the 6th gens, let me get that out there now. The concepts are the same:
If you want to do a head back exhaust then order an ex header, and ex downpipe, and an ex catback. If you want to do an ex cat back then you'll need to have an ex header and down pipe. if you just want a muffler, then just pick up an axle back muffler and bolt it on, or have it welded, depending on the muffler- pick up the kind that bolt on instead of the kind you have to weld one- its just easier and you can convert back to stock without re welding.
The issue of the O2 sensors... stick with the LX ones and just buy extention cables, links are in the first post. If you pick up the EX ones, you'll have to cut the connectors and solder them together because you cant join too females or two males with eachother.
Hope that helps. *crosses fingers this only posts once the first time*
Old Feb 22, 2009
  #174
m3Lo1523's Avatar
Woah really LOL. Nah seriously I was just wondering.
Old Feb 22, 2009
  #175
In reality probably 1 to 3 hp. Pretty impressive hunh. No bolt-on is gonna give you any significant power increase on your civic. Try just driving like a tool every now and then and pretend it's fast, that's what I do.
Old Feb 22, 2009
  #176
Mavrick272's Avatar
Yeah, I most certainly don't have pipe skills, let alone many car skills.
I appreciate the help
OK, so I want to do a header back. So you say I should get an EX head, EX downpipe and EX catback. By that I'm assuming you mean OEM EX head, downpipe and catback. That sounds good, but would getting the OBX header, some kind of cat that I can have a muffler shop weld to it and the OBX catback work as well?
Would the OBX head/cat line up with the rest of the exhaust nicely I guess is my main concern
Old Feb 22, 2009
  #177
m3Lo1523's Avatar
Haha that's cool was just wondering!
Old Feb 22, 2009
  #178
Mavrick272's Avatar
It looks like both the OBX cats are the bolt-in type
So I put the OBX head on, bolt the cat to it, get the o2 sensor extenders (they'res an o2 sensor before and after the cat, correct me if I'm wrong) and then figure something out to piece between the cat and the cat back and I'm golden....right?
*crosses fingers*
Old Feb 22, 2009
  #179
m3Lo1523's Avatar
Old Feb 22, 2009
  #180
TRIZ's Avatar
You keep saying "ex head" Your ex head and lx head and dx head all have the same bolt pattern, so you dont need to change the head to change the manifold that bolts to it. I think your also getting the parts mixed up a little- you cant weld a cat onto a header... well, I guess you could, but that would just be stupid and it would probably be an inch from the pavement so you couldnt run a cat back. Here is how the parts go:
Engine Head> header (exhaust manifold)> Downpipe with cat converter in it (this is one piece of pipe with flanges on either side and the cat in the center [if you cant get a hold of an OEM downpipe with cat, get the Random Tech pipe, OR get a test pipe and a universal weld-in cat], then your cat back exhaust system.
