Turbo Post information/questions about Turbo here!
Turbo causing A/C to not work
Old Jul 19, 2007
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
One of the A/C lines passes approximately 1" away from the bend in my downpipe as it is exiting the turbo. Over the past 2 years, I've been noticing my A/C didn't get as cold as the year before (which is normal - I guess) but this season I've put the turbo on, and now it only blows hot air. Is this because the heat of the downpipe screwed up the freon or whatever's in there (and recharging is only a temporary solution)?
Or is it that simply my higher engine tempertures are just making the stock A/C system ineffective to cool the air enough? ...and recharge or not it still wouldn't work?
It sucks driving 30 miles home every day and its 97º out with 80% humidity and no A/C.
Old Jul 19, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Turbo causing A/C to not work
Check the pressure in the AC lines, make sure you have refrigerant in there and the system isnt leaking. Check the compressor, make sure its working.
You can wrap the DP to keep it cooler, but I dont think thats gonna matter, the AC is probably unrelated to the turbo.
Old Jul 19, 2007
So you're saying the refrigerant wouldn't be affected by the heat? I mean - I like good news - it's just that I've had so much bad luck so far I halfway expect someone to tell me I blew it up again... LOL.
Old Jul 19, 2007
DsevenEm2's Avatar
This is Myspace
if recharging ur system only works temporarily its probably got something to do with the compressor. that refrigerant stuff is pretty cold. thats what happend to my moms old buick. that refrigerant was a temprary fix...even though its suppose to work good for a long time. it was the compressor....and if i were u...(i dont have turbo and i probably never will) if my turbo is close to any lines or cables or whatever...id wrap it up. but thats just me..
Old Jul 19, 2007
drunkenmagnum's Avatar
Originally Posted by LogicWavelength
...someone to tell me I blew it up again... LOL.
you blew it up again, sorry
j/k i had the same problem with mine after i turboed. never quit got the same cold air as before. at one point i did have a hole in my ac condensor that slowly leaked the coolant out. just get a mechanic to put dye in your system to check. the problem is sometimes the leak may be hidden cuasing you to remove your bumper to find it.
Old Jul 19, 2007
PunkingCivic's Avatar
I need TP for my bunghole
I second the dye treatment test for leaks
Old Jul 19, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I dont thing it is the issue with turbo heating up a/c lines. Mt dounpipe is just 1/4 in away from aluminum a/c pipes. A/C blows cold. I dont even think heat from the turbo affects it much.
I'd check a/c lines, a/c clutch and then a/c compressor. Mostlileky you have a leak of some sort.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Supramk3
May 8, 2015 11:16 AM
ORskier
May 3, 2015 12:54 PM
trevor
Dec 4, 2001 04:12 PM
slammed2k1civ
Nov 27, 2001 11:29 PM
