Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
d17 transmission with d16 engine
Old Oct 29, 2020
stoge37's Avatar
stoge37 is an unknown quantity at this point
i have a 2004 non vtec civic lx 5 speed
and a 1999 civic ex auto
i know that the d16 stock has more hp vtech wise and the d16 has less miles i want to put the d16 from the 99 into my 04 with my 04 transmission i just rebuilt how can i make this work?
d17 rebuilt transmission i want to mate with this engine..
d16y8 engine in this car...
2004 civic lx manual transmission
i basically want to put a d16y8 into a 04 with the d17 trans so i dont have to mess with linkage and use same motor mounts and cv axles?
Old Oct 29, 2020
FRSam's Avatar
Click Here
Re: d17 transmission with d16 engine
Way more of a pain in the *** than it's worth. The trans will work but there's so much custom crap involved to fit a D16 in a 7th gen chassis, not to mention the legalities associated with it. You'll need the D16 to be at least as good on emissions as the D17 you'll be removing, and I'm not sure that it would be. Either way, it's too big a pain in the ***, especially for the sake of maybe 10hp. It would make more sense to K-swap or boost than it would be to drop a D16 in. I'm not sure it'd be all that much more expensive, either.
Old Oct 30, 2020
stoge37's Avatar
motor mounts
ecu and wiring
starter location
thats all i can think of really and i have every tool ever made and weld fab ready **** it why not right?
Old Oct 30, 2020
Colin42's Avatar
Be alot less work to put the trans in the 6th gen. Which is a much better chassis, and platform for modding. Still not worth it.
Starter is in the exact same spot, so maybe more/better research is needed
You can get a used trans for under $150
Old Oct 30, 2020
FRSam's Avatar
Click Here
What state do you live in? The legalities of it are what's stopping you.
Old Oct 30, 2020
BrotatoChip's Avatar
Super Moderator
As long as you don't have any emission testing you can but like others said it won't be easy.
buzzshipman
Sep 2, 2005 01:38 PM
flowerpowerlove
Engine Swaps
Oct 23, 2004 06:12 PM
kezay
Jul 11, 2004 02:49 PM
Wes
Jul 16, 2002 04:41 AM
