Difference between d16 engine and d17 engine
Old Apr 15, 2003
buzzshipman's Avatar
buzzshipman is an unknown quantity at this point
I was wondering what the differences were between the d16 and the d17. I know the d17 is more displacement of course and that it has direct ignition. I was more wondering about cam profile and internal parts. There are performance cams for the d16 but nothing that I have found for the d17. Was wondering if I could use those. If not, does anyone know of cams or other performance parts for the d17.
Thanks,
Kevin
Old Apr 15, 2003
Got Boost???'s Avatar
i don't believe ANY performance parts are interchangable bewteen the d16 and d17. Off hand the only difference i know besides displacement is compression ratio.
D17A2 9.9:1 <-- 2001 EX
D16Y8 9.6:1 <-- 2000 EX
well after doing some research, turns out we have the same bore, so pistons MIGHT be swapped.
Our throttle body is on the top of the intake manifold, while the d16 is on the side. So intake manifold, throttle bodies and intakes can't be swapped.
I doubt something precise like cam shafts would be interchangeable
Old Apr 15, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Do a search on D17A2. A thread i started a while back for the same info. There are others interested also...
BTW you can get custom grinds done for your cam. Crower & Gude are 2 places willing to do so
http://www.gude.com
http://www.crower.com
Old Apr 15, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
d17-d16=d1?
Old Apr 15, 2003
XxSoVeReiGNxX's Avatar
Originally posted by iluvbritney
d17-d16=d1?
lol muthaf**ker! LOL LOOOOOOOOOOOOOOOOOOOOOLLLLLLLLLLL!!!
Old Apr 15, 2003
djmota's Avatar
http://www.heeltoeauto.com/dseries/dseries1.html
Check this site out Its a really good comparison of d series pistons
Old Apr 16, 2003
branden's Avatar
branden is an unknown quantity at this point
2001 VTi Philippine models have a D16 engine on it. its throttle is also on top of the manifold and produces 127hp. headers and other bolt-ons fit our engines. Most of the parts here are imported from the US which has the D17...
Old Apr 16, 2003
txtadik's Avatar
txtadik is an unknown quantity at this point
doesn't the D16 in the philippines produce 130hp?
any news of the RX Civic coming to the philippines? that's one suuuweeeet sedan! K20 baybeeee!
Old Apr 16, 2003
branden's Avatar
RX civic? no news yet...K20 that's nice!!! i don't know the conversion with ps and hp....but i think its 127ps or 130hp....wouldn't that be the same for the D17?
tsong, kung miss mo na rin pinas, bakit di ka magbakasyon...
Old Sep 2, 2005
jky's Avatar
jky
jky is an unknown quantity at this point
please, write whole nubers not only D17 and D16.
There are too much D16 engine in hondas !!!
In Europe we have D16V1 suposedly identical to D17A2 except the rods, but not 100% sure. I am looking for a new Electronic parts catalog to see in the head has the same catalog number.
Old Sep 2, 2005
turboengnr's Avatar
DONT PANIC
pistons cannot be swapped.
The closest motor to the D17 is the D16a (ZC)
----------D17-------D16A(ZC)
C-C------5.394------5.394
BE Bore---1.890------1.890
BE Thick---.780-------.892 Width of the Bearing surface on the rods are different
PE Bore----.748--------.748
(mm)-------19--------19
PE Thick---.900--------.710 Width of the top of the rod for the wristpin is different
Those are enough to make the parts non-interchangable.
The only way to run a D16 piston in a D17 would be to have a custom rod made.
Old Sep 2, 2005
turboengnr's Avatar
DONT PANIC
also, the D16 tranny will bolt onto our motor. You would have to build a custom shifter and linkage.
I already tried it, but scraped the project due to lack of time.
Old Sep 2, 2005
streetglower's Avatar
closed to do the date of the thread and since this info has been posted numerous times.
Bruce.Ringler
Jun 18, 2015 08:12 AM
Paul Harsze
May 20, 2015 11:37 AM
zack22490
Apr 29, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
supercivic01
South
Nov 30, 2001 11:27 AM
