Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
Anyone get A/C working on a K-Pro D17?
Old Aug 10, 2020
RallyeRedEM2's Avatar
RallyeRedEM2 is an unknown quantity at this point
'05 EX Coupe M/T
I put in a K-Pro with the AEM D17 timing gear, now, the A/C doesn't work
I read somewhere Hondata can't incorporate the A/C to work since the stock ECU modulates "stuff" with the engine when the A/C compressor kicks on.
Do I have to wait until I k-swap this thing to get A/C working again??
Anyone have A/C with the K-Pro on the stock D17?
Old Nov 6, 2020
WUWU20's Avatar
WUWU20 is an unknown quantity at this point
Re: Anyone get A/C working on a K-Pro D17?
Where did you find a K-pro for a D17?
Old Nov 6, 2020
FRSam's Avatar
Click Here
Check Hondata's website. You've been able to run KPro on D17's for years.
https://www.hondata.com/kpro-d17
Old Nov 6, 2020
https://www.hamotorsports.com/produc...49ba6486&_ss=r
You can pre-order one from HAMotorsport. That’s where I got mine. I bought mine back in June before they sold out. They’re reputable.
the A/C works
I forgot to plug in the evap temp sensor
Old Nov 13, 2020
WUWU20's Avatar
what are the gains with a K-pro? I race a 7th gen on dirt and pavement and I need everything I can get BUT when tech opens the hood it needs to look "stock" I don't need more RPM/s I need torque and HP. Are there maps for changing timing and fuel?
Old Nov 14, 2020
bryan.0831's Avatar
bryan.0831 is an unknown quantity at this point
My A/C doesn’t work. I contacted Hondata and they said it’s not the kpro issue. I couldn’t figure it out. So I just hot wire mine to a switch and use it when really needed. Usually just rolling the windows down is okay with me.
Old Nov 15, 2020
in can unlock locked power if you have already done mods.
if no mods, not likely to get much.
as proof, the crower stage 1 cam (discontinued) in a D17A2 does not need a hondata to unlock potential - just drop the cam in and it gets a lot more power/torque.
Redviking
Engine Management
48
Jul 29, 2022 09:06 AM
civcspool
Engine Swaps
16
Nov 27, 2008 12:32 AM
05civicFun
Oct 10, 2006 06:54 PM
flowerpowerlove
Engine Swaps
Oct 23, 2004 06:12 PM
iLLuMiNaTi
Aug 6, 2003 04:59 AM
