Hondata k-pro
Old Oct 31, 2008
civcspool's Avatar
civcspool will become famous soon enoughcivcspool will become famous soon enough
Hondata k-pro
will 2002-2004 RSX Type S 6 speed (PRB-A0 - ECU) k-pro fit on a d17 or do I have to get it reflashed? it doesnt have the base map for d17.. but I think my tuner can start from scratch but the question is it the same software running from k20 and d17?
Old Oct 31, 2008
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Hondata k-pro
yeah i'm pretty sure it is, but you do need that modified cam gear if you don't already have one. as far as i understand it, k-pro is the same no matter what engine you run it on. i'm also pretty sure you can get the basemap for the d17 online. if you install the hondata software that runs it, it comes with a ton of basemaps, and the d17 map is one of them. don't start from scratch... thats just throwing money away.
Old Oct 31, 2008
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
Re: Hondata k-pro
You hit the nail on the head baron!
Old Oct 31, 2008
d17civickid's Avatar
d17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of lightd17civickid is a glorious beacon of light
Re: Hondata k-pro
rsx computer connects right to the d17 harness right?
Old Oct 31, 2008
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
Re: Hondata k-pro
it connects, yes.....is the pin out the same, no
Old Oct 31, 2008
supafil25's Avatar
supafil25 will become famous soon enough
Re: Hondata k-pro
so do you pull the pins out or is there a jumoer harness?
Old Oct 31, 2008
ronaldo9's Avatar
Re: Hondata k-pro
This info can be found on Hondata's website and Andyman I'm pretty sure has a diy on this.
Old Nov 1, 2008
You VTEC...I-VTEC
Re: Hondata k-pro
there are jumper harnesses you can buy if you arent comfortable repinning. hybrid racing makes one...i dont think it is listed on their website but if you call them i believe they can make them. My jumper is a hybrid racing one and I have no issues with it
Old Nov 7, 2008
aspech's Avatar
aspech is an unknown quantity at this point
Re: Hondata k-pro
you need the d17 cam gear + the kpro.
hondatas website shows you how to re-pin for the d17 i believe.
Old Nov 19, 2008
01_EM2's Avatar
01_EM2 can only hope to improve
Re: Hondata k-pro
ok im saving my money for the kpro and im very confused as how to go about it. i cant use my stock ecu??? thats what the hondata site says!! so i have to buy ANOTHER ecu for an rsx just to get the kpro??? very confused
Old Nov 19, 2008
01_EM2's Avatar
Re: Hondata k-pro
Old Nov 19, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
Re: Hondata k-pro
yes. the d17 kpro fits inside an rsx or ep3 ecu case. the connectors are the same as the d17 ecu, but the pinouts are different so you'll have to re-pin the connectors (not extremely difficult) or get a jumper harness as mentioned above.
Old Nov 19, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: Hondata k-pro
you can't use the d17 ecu you can use the case with some modification for the usb port (you have to cut a hole out for it).
According to hondata the d17 board can not be rewritten same goes for the s2000 but the rsx/si ecu can be rewritten so you need the board out of the rsx ecu so basicly you need the rsx ecu hondata's website will tell you which ecu are compatible.
as far as repinning even thought the shop manual tells you how and some people say it is not that hard I have found it extremly difficult because you do run into some connectors that don't want to give up those damm pins. So I just went up the wire a couple of inches cut it and then soldered it to where it was supposed to go
Old Nov 20, 2008
andyman97's Avatar
Turbo Guru
Re: Hondata k-pro
Depending on the year of the car, there are a total of two wires that need to be switched... I haven't seen a company make a jumper harness for two wires, that wouldn't make any sense....
The only wiring you have to do is for the o2 sensor (if you want to run closed loop). To be perfectly honest, you can plug it in, make changes to the map and you don't have to do ANY wiring at all if you choose not to.
Old Nov 20, 2008
Rufus's Avatar
Re: Hondata k-pro
Plus I put the CRV ECU right in. It's identical to the d17 case
Old Nov 21, 2008
td-civ's Avatar
td-civ is an unknown quantity at this point
Re: Hondata k-pro
k-pro can be used for any 01 and up honda you just have to change settings and tune for you motor i have used a prb k-pro ecm on a 02 civic with a d17 and it runs fine made almost 30hp over stock
Old Nov 27, 2008
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
Re: Hondata k-pro
all said and done^^^^^^^^kpro is the ****
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
NROD315
Sep 4, 2015 09:22 PM
Matt02222222
Aug 10, 2004 08:39 PM
civicvtec1ps
May 7, 2004 04:44 PM
civicvtec1ps
Jan 24, 2004 05:08 PM
