Alignment
Old Dec 1, 2018
rose62's Avatar
rose62 is an unknown quantity at this point
Alignment
On my 2001, the outside of the passenger side tire is wearing. Jacked it up and can't see any obvious slop. What is a typical place to find worn parts in these cars?
Old Dec 1, 2018
Re: Alignment
the compliance bushing in the lower control arm, the big one.
when was the last time you aligned? Recommendation is once a year.
lots of parts could be culprit at the age our cars are. Mine was tie-rod.
Old Dec 1, 2018
rose62's Avatar
Re: Alignment
I've had the car a bit over a year and never had it in the shop. It has 160K on it. This front suspension (except the struts) is a totally foreign design to me. Very strange looking, such as the rack location and the use of vertical pivot bushing at the leading edge of the LCA.
Old Dec 1, 2018
Re: Alignment
yes, that is the compliance bushing - that is the usual one that gets torn.
PS: I usually swap the arms completely, they are not that expensive - pushing the bushings in takes more money in the end
but i recommend having a shop look at it - it just might need an alignment
Old Dec 1, 2018
rose62's Avatar
Re: Alignment
"but i recommend having a shop look at it - it just might need an alignment."
Good advice. Thanks.
Old Dec 1, 2018
Re: Alignment
good luck! If they give you a high price, come back and tell us and we will see how it is
Old Dec 2, 2018
Re: Alignment
this just popped this morning.
the bushings that are not where they should be?
Those are the compliance bushings i told you
https://www.civicforums.com/forums/1...trol-arms.html
SlowboyZ
Suspension
Apr 14, 2017 03:18 AM
Civicnoobie
18
Sep 20, 2014 09:05 PM
sierioiza
Oct 18, 2011 07:20 PM
CivicRage
20
Aug 23, 2010 03:02 PM
skalin
Jul 30, 2010 11:50 AM
