Idle Issues If you have idle issues, post here!
IAT code P0113
Old May 12, 2020
  #91
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: IAT code P0113
Originally Posted by Tracecross30
i rebuild it myself. Couldn't pay for that as i just had my 07 scion wrecked so i couldn't afford some better at the moment.i did a compression test and i was getting read like between 75psi and 80 on all of them..the car starts fine but its just the rough idling, sureg idling and the IAT issues and maybe because of these issues,I'm burn more gas.cant wait to have the issues solve mon.
Presuming the compression test was done correctly and the gauge is accurate 75-80 is way too low, the minimum spec is 135 and a good engine will be well above that. If the compression was really that low I don't know that it would even start.
Old May 12, 2020
  #92
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Re: IAT code P0113
Originally Posted by D17VTECPOWER
Presuming the compression test was done correctly and the gauge is accurate 75-80 is way too low, the minimum spec is 135. If the compression was really that low I don't know that it would even start.
sorry man, 175 psi and 180 lol..
Old May 12, 2020
  #93
Re: IAT code P0113
Oh, that is good then. No need to replace the engine or worry about the rings
Old May 12, 2020
  #94
Re: IAT code P0113
the first time i took the car to the dealer when i was having my overheating issue,the dealer said theres was no head gasket issue and i had to do some research and realized that my head gasket was blown and thats how i work on it myself.the very first time messing with a car engine on my own as well. And replace the bearings in the tranny to but i manage to get it done with self confidence.i couldn't pay to do all those work.thanks to youtube and this forum.you guys Mostly helpful.
Old May 12, 2020
  #95
Re: IAT code P0113
i might just go ahead and spend time and make me a smoke pan and do a smoke test just to make sure theres no vacuum leakes for sure. What you think about the evap canister? It causes vibrations and rough idling when they go bad too. I read anout on line but i dont want to invest in too much part just yet.i spent $400 On idle air control valve at the dealer and it didn't solve my problem.i was mad.
Old May 12, 2020
  #96
Re: IAT code P0113
It is possible that the EVAP purge solenoid on the throttle body is stuck open and allowing too much flow. That should set a code, but don't rule it out as a possibility. You can disconnect and plug that off too and see if it makes any difference, it's easy enough to try. Do you hear any hissing noises around the engine like air is getting sucked in?
Old May 12, 2020
  #97
Re: IAT code P0113
no i dont hear any issing. But when i put my finger over the idle air valve inside the throttle body it should suck hard on my finger or stall but I'm not feeling anything like that.
Old May 12, 2020
  #98
Re: IAT code P0113
You definitely have a pretty large vacuum leak then, the engine must be getting air from somewhere or it would die out. I do a similar test putting my hand over the throttle body while its running. The engine should immediately die out and it should hold a vacuum for a while, if it doesn't its getting air from somewhere else.
Old May 12, 2020
  #99
Re: IAT code P0113
there's a different though. If i put my hand over the throttle body it immediately suck in my hand and stalled out but if i put my finger over the hole inside the throttle body for idle air valve it doesn't do that though. I'm wondering if thats normal.
Old May 12, 2020
  #100
Re: IAT code P0113
Once the engine stalls does it hold a vacuum or does it quickly lose the vacuum? The only reason covering the IACV hole would be different than covering the throttle body is that a little air can get around the throttle plate even when its closed, but not enough to keep it running by itself from my experience. Does the throttle close all the way?
Old May 12, 2020
  #101
Re: IAT code P0113
yes, the butterfly fully closed and the throttle bod is clean all over inside. The evap solenoid should suck only one way ,right?
Old May 12, 2020
  #102
Re: IAT code P0113
Yes, the EVAP solenoid should only pull air into the intake manifold, and it should not suck with the electrical connector unplugged.
Old May 12, 2020
  #103
Re: IAT code P0113
ok understood.alright mon.i will do some a smoke, evap test like you explain, brake booster hose test and let you know soon. I will do the brake booster hose and the evap solenoid tomorrow.
Old May 13, 2020
  #104
Wankenstein's Avatar
Re: IAT code P0113
Code P0113 will not be caused by a vacuum leak, IACV, PCV valve, etc. There are 3 things that can cause it: A bad IAT sensor, bad wiring or connections, or a bad ECU. Since you replaced the sensor and the problem is still there, we can reasonably assume the problem isn't the sensor.
That leaves wiring and ECU. Does the plug fit in the IAT sensor tightly? Is there any corrosion in the plug? I presume you visually inspected the IAT wiring for damage? ECUs very rarely fail so if I had to bet I would bet on the problem being either a bad connection at the plug or damaged wiring. Do you have a scanner that will show live data like intake air temp and sensor voltage?
OP posted another similar thread and told him to check harness for visible damage, measure voltage and continuity at IACV and IAT harness connectors, and mentioned the possibility of a failed ECU. He doesn't seem to want to test anything and would rather slap parts on it in hopes a fix. OP please always test first as much as possible and then replace parts if need be. You'll learn more, save money, and wont get scolded by dicks like me.
Old May 13, 2020
  #105
Re: IAT code P0113
i already test the IAT connection and unplugged the IACV while the vehicle is running and it makes the engine struggled so that tells me it getting sufficient current to it the sensor. Next i will check the evap canister solenoid today and do another smoke test.
Old May 13, 2020
  #106
Re: IAT code P0113
im not intended to put lots of money into it like i did,spent $400 buyin IACV and nothing changes.
Old May 13, 2020
  #107
Re: IAT code P0113
so i just done two tests that you told me to do. The evap canister solenoid. I started the car and pulled the hose hose and put my finger over the hose, as you see in tje pic where I'm pointing at
And it was sucking in on my finger so that tells me that its work as it should. Next one i tried,not sure the name of it but i think they work together as one, evap canister,Evap solenoid and the other one where I'm touching with the socket extension
The one I'm touching with the socket extension, i unplugged it and immediately the car was shutting down so i know that one is working well also.next i Will do the third smoke test. Not sure how to test the Evap canister.
Old May 13, 2020
  #108
Re: IAT code P0113
I forgot that you asked if i turn intake manifold gasket wrong? I didn't turned it wrong and i removed the intake manifold about a month ago just rechecking on things and i carefully inspected the way it turns and how it should lign up and it was in the correct order.
Old May 13, 2020
  #109
Re: IAT code P0113
Ok. Did the idle normalize when you plugged off the EVAP solenoid with your finger? Also, that thing you were pointing at with your socket extension is called a MAP sensor, basically it tells the ECU how much of a vacuum is in the intake manifold so it knows how much air is going through the engine, it needs to know this so it knows how much fuel to inject. It doesn't really have anything to do with the EVAP system. Have you tried disconnecting and plugging off the brake booster hose yet?
Old May 13, 2020
  #110
Re: IAT code P0113
When i putvny finger over the evap solenoid the idle didn't change but it suck the hell from my finger and click click though. Yes,i unplugged the brake booster hose,before i unplugged it i pinched it with the pliers and the engine was about to stall out.
Old May 13, 2020
  #111
Re: IAT code P0113
I think you found your issue. Do you mean the engine was about to stall out when you pinched the brake booster hose with your pliers? Pinching the brake booster hose should have no effect on the idle unless the booster has a leak.
Old May 13, 2020
  #112
Re: IAT code P0113
oh really? I thought thats normal if its stalled out by pinching it because the passage is blocked off. So if i have a leake like you are assuming i might have,why when i did all the tests with brake cleaner and soap water i didn't get any result. Strange.!
Old May 13, 2020
  #113
Re: IAT code P0113
You won't find a brake booster leak with smoke, the hose has a one way valve in it that won't allow air (or smoke) into the booster. The reason it is stalling out when you correct the problem by pinching the line off is because the ECU has the IACV closed off trying to compensate for the leak since air is entering through the booster when it shouldn't be. Try this. Disconnect the vacuum line from the brake booster, plug it off with a bolt or something, clear the codes so the ECU forgets about the leak, start the engine, and see if it runs correctly and if the code comes back. If it does you know for certain the booster is the problem. As you know you will have almost no brakes without the booster connected so don't try driving it though!
Old May 13, 2020
  #114
Re: IAT code P0113
[QUOTE=D17VTECPOWER;4775769]You won't find a brake booster leak with smoke, the hose has a one way valve in it that won't allow air (or smoke) into the booster. The reason it is stalling out when you correct the problem by pinching the line off is because the ECU has the IACV closed off trying to compensate for the leak since air is entering through the booster when it shouldn't be. Try this. Disconnect the vacuum line from the brake booster, plug it off with a bolt or something, clear the codes so the ECU forgets about the leak, start the engine, and see if it runs correctly and if the code comes back. As you know you will have almost no brakes without the booster connected so don't try driving it though![/QUOTE
Ok so you definitely saying the hose has a leak somewhere along the line? Other than the vibrating and the RPM surge when i stop or just idling normally, it idle fine but i will do this when i get home and post back.
Old May 13, 2020
  #115
Re: IAT code P0113
[QUOTE=Tracecross30;4775772]
If pinching off the hose to the booster is affecting the way it runs then yes the booster is bad and is almost certainly what is causing the P1505 code and could be causing a vibration. A leaking booster will have the same effect as a cracked manifold, bad gasket, etc. Plugging off the hose will simulate a correctly functioning booster and it should idle and run correctly with no surging and it shouldn't set the P1505 code.
Old May 13, 2020
  #116
Re: IAT code P0113
[QUOTE=D17VTECPOWER;4775773]
Ok understood. I might get a brake booster from the junkyard to replace that one. I changed the brake booster that was on there for this one thats in place now..
Old May 13, 2020
  #117
Re: IAT code P0113
[QUOTE=Tracecross30;4775775]
ok guys, problem seem to be found and fixed but not officially fixed as yet. I pinched the hose again while the car idling and it stalled out but didn't shut off. I turn it off the car and moved ECU fuse, disconnected the hose and plugged the end with a 3/8 extension and turned it back on and pinched it again but it didn't stalled,instead it idle as normal. And i let it idle for awhile and pressed the gas pedal and the RPM wasn't acting like it was instead it goes down to normal when i released the gas pedal. So now i know its the brake booster bad. Now i need to find the source for IAT Sensor that causing the p0113 code. I have to chech the wire like u told me.
Old May 13, 2020
  #118
Re: IAT code P0113
[QUOTE=Tracecross30;4775783]
Awesome, glad you found one of the problems! Do you still feel that vibration you were talking about or does it run smoothly now?
Old May 13, 2020
  #119
Re: IAT code P0113
[QUOTE=D17VTECPOWER;4775784]
i still feels vibration but not as it was. It might be the valve need propper adjustment or the mounts. You can see the engine vibrate. I know hondas dont vibrates that hard.but that's not my big issue though.thanks very much for all you guts help.
Old May 13, 2020
  #120
Re: IAT code P0113
[quote=Tracecross30;4775788]
I would start with the basics. A valve adjustment is easy and free so I would start there. Here is a video on how to adjust the valves if you don't already know. Checking the spark plugs and changing them if they are old or worn out wouldn't hurt either. What year is this car?
