Clutch/Shift Level
Old May 7, 2023
HybridHonker's Avatar
HybridHonker is an unknown quantity at this point
Clutch/Shift Level
New here so if I'm in the wrong area let me know. I have a manual 2003 Honda Civic Hybrid. Probably around a month ago my shift lever is having a difficult time going into gear even while depressing the clutch. It's got to the point it resists my efforts and I have to put a lot of force, to force it into gear. Also, once in awhile it shifts into gear effortlessly as it did in the past. This happens every now and then but few and far between. I've changed the transmission fluid. Friends suggest bleeding the master cylinder. Others think I might need a clutch adjustment. I replaced the clutch and flywheel 6 years ago. So I'm pretty certain that isn't going out. Any suggestions or ideas why this might be happening all of a sudden? Thanks!
Old May 7, 2023
Re: Clutch/Shift Level
check hydraulic clutch activation system
if you don't know what his means, take to a transmission shop
Outdoorsman
Transmission
May 17, 2020 09:52 PM
threeoten
Transmission
Dec 10, 2015 11:08 PM
conquesimo
May 19, 2011 08:27 PM
V4sh
Aug 29, 2009 10:25 AM
bullseye
Jul 21, 2004 03:05 AM
