Push it to the floor to start
Old Mar 30, 2023
mkeschinger's Avatar
mkeschinger is an unknown quantity at this point
Hi,
2001 honda civic ex coupe manual -I have to press the clutch to the floor to start and to shift into 1st. A friend who has a few civics says that that's not normal.
It shifts pretty smooth otherwise. Question is, is that the way it's supposed to be for this generation civic?
I appreciate the help.
MK
Old Mar 30, 2023
Re: Push it to the floor to start
there is a switch at the pedal, check it
Old Mar 31, 2023
BrotatoChip's Avatar
Super Moderator
It sounds like the clutch is working as it should. I don't understand.
The clutch has to be pressed all the way down before the car will start. This is to avoid someone starting the car while in gear and hitting something. Clutch has to be pressed all the way down to get into gear as well, that's literally it's job.
Old Mar 31, 2023
Colin42's Avatar
100% this
Cheyenne1978
Engine start problems
Sep 18, 2022 07:29 AM
3rdEyeTilliDie
General 7th Gen
Apr 24, 2022 09:08 PM
Aerose91
General 8th & 9th Gen
Dec 18, 2018 08:38 PM
hockeykid
Aug 29, 2012 06:20 PM
AnnoD04
Jul 10, 2010 06:59 PM
