I can't figure it out plz help
Old Jul 21, 2022
Lisacavell41's Avatar
Lisacavell41 is an unknown quantity at this point
I have a 2001 Honda civic and I jus replaced the gear shift and the cable that runs from the gear shift to the transmission, the cable that makes it go into gear. But I'm having the same problem. I can drive it for only a few mins bc once it gets hot it stops shifting. It will jump out of gear and not move. I don't know what else to fix. Is it my transmission all together bc when I got the car I was told the transmission was fairly new. Plz help me bc I have kids and a job and I'm having trouble getting anything done without my car.
Old Jul 21, 2022
FRSam's Avatar
Click Here
Re: I can't figure it out plz help
Have you checked the state of the transmission fluid? Is there any fluid at all?
Old Jul 21, 2022
I did have someone check and they said I was good but then someone else checked a few days later and said I need some so I got some and I'm getting someone to do it today for me
Old Jul 21, 2022
FRSam's Avatar
Click Here
That will be what your problem is. Here's to hoping you address it quickly enough - otherwise you may need another transmission.
Old Jul 21, 2022
Harry Hemi's Avatar
Harry Hemi is an unknown quantity at this point
This sounds like the internal filter is clogged, and the transmission is toast. It quits when it gets hot because the clutch material running throughout the fluid clogs the filter and prevents fluid flow.
Old Jul 22, 2022
BrotatoChip's Avatar
Super Moderator
That very well could be, '01-'02 I think were the worst with that issue. Let's see what adding ATF does, maybe they will get lucky.
Old Jul 23, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Use only genuine Honda fluid! My 2003 shifted like crap on aftermarket fluid. After I dumped and refilled issues were gone. I have to do it again now that the old crap is getting worked through its shifting goofy again.
impetigo
Transmission
24
Jan 21, 2021 04:49 PM
crystalsky93
Transmission
May 8, 2019 01:05 PM
EC3
Apr 22, 2015 07:55 PM
javii_em1
Mar 25, 2013 10:04 AM
patkinson
Buy, Sell, & Trade - Archive
Jul 19, 2009 04:16 PM
