Question on transmission mount
Old Feb 2, 2019
jeep8589's Avatar
jeep8589 is an unknown quantity at this point
I have a 2005 Civic VP and I replaced the transmission mount. The old mount had a cast iron piece of steel that was held onto the top of the mount with 2 small bolts. The new mount did not have ears welded on that it mounts to. When I looked where this piece of steel sits on the transmission mount, it does not touch, support, or appear to do anything. What is this little piece of cast iron for, and does it do anything. My thought was that this is something for a manual transmission, or for a different model that Honda found it easier to just use one mount for all of them. Could someone give me some insight on what this does, and why the majority of the replacement mounts that are made do not have the provisions to put it on.
Thanks for the help.
Tags bracket brace
Old Feb 2, 2019
Colin42's Avatar
Re: Question on transmission mount
Pictures would help
Old Feb 2, 2019
jeep8589's Avatar
This is the part that I am talking about.
Weight, Transmission Mounting - Honda (50830-S5A-A02)
It is the weight that is held on by the bolt on the top. You can buy the mount with and without it, but most come without it.
Old Feb 2, 2019
Colin42's Avatar
That's a counterweight to help with vibrations, On my truck there was a massive one hanging of the back of the transfer case
Old Feb 2, 2019
jeep8589's Avatar
Thanks for the response. I guess if there is a vibration issue, I can tack weld the mount onto it. It is weird that a 6oz piece of metal would really make that much of a difference.
Old Feb 2, 2019
Colin42's Avatar
engineers
Misbah
Feb 13, 2013 09:03 PM
tinktink36
Dec 12, 2012 01:41 AM
smalie1978
Oct 30, 2011 02:17 PM
InsaneImages
Engine Swaps
May 17, 2006 04:42 AM
CarbonFly
Aug 12, 2003 01:58 AM
