Mounts (MT)
Old Sep 12, 2011
smalie1978's Avatar
smalie1978 is an unknown quantity at this point
Question Mounts (MT)
Saludos,
Based on experience ... Which mount (Engine/Transmission), usually starts to break-up first ???
Old Sep 12, 2011
Re: Mounts (MT)
the one in the front middle, near the radiator. the back one and two sides hardly ever go bad.
Old Oct 10, 2011
smalie1978's Avatar
Re: Mounts (MT)
Thank you
Old Oct 10, 2011
Re: Mounts (MT)
here is what it looks like on a manual. you could get the energy suspension bushing inserts that install around the old mount. So long as you did not break more than 1 of the 2 rubber mount legs, you can reuse the old one and stick on the inserts. Even with a new front mount, it will keep breaking again (usually members here say every 10k miles it will start to crack and break) due to poor design. the older hondas never had this problem. the energy inserts should last the life of the car and may cause a bit more vibration, but its worth having a stronger mount i think. front mount is #8 in the pic.
Old Oct 10, 2011
ZFreak's Avatar
Honda Crazy
ZFreak is an unknown quantity at this point
Re: Mounts (MT)
It's the mount to the front of the car underneath. The easy way to tell which one it is is by the color. It is the only mount that is aluminum (silver) on the outside. All the other ones are black.
Old Oct 29, 2011
04 Honda Civic's Avatar
Re: Mounts (MT)
Hey gearbox, will the ES busings work if my front mount is already broken? Also it says only for manual is it ok to use for an automatic as well? I am refering to these:
http://www.energysuspensionparts.com...prod=16%2E1111
Old Oct 30, 2011
Re: Mounts (MT)
if only one leg of the stock mount is torn, then the es bushings are fine to use. usually thats all the damage they have. the front two inserts fit perfectly on the auto mount. i used my stock mount with one broken leg and the ES fixed it like new. you put them in like a sandwich with one insert on the left side and one on the right side. the two rear mount inserts i ended up not using.
Old Oct 30, 2011
MindBomber's Avatar
Live for the Twisties
Re: Mounts (MT)
ESMM inserts are the best bang for the buck mod I have, no contest
Old Oct 30, 2011
Re: Mounts (MT)
Awesome, thanks. I really cant afford to keep ordering these from the dealer at $45 a pop. Going to order a set of these now. Once again thanks.
mgrantaz
General
May 2, 2022 05:40 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
