Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Cooling system water still blue after four rinses
Old Aug 11, 2022
niemand's Avatar
niemand is an unknown quantity at this point
I've been draining (from the radiator petcock valve) and filling (from the radiator filler) the 2002 Civic LX 1.7L cooling system with distilled water. I've done this four times now, each time followed by running of the engine until the fans have come on twice (which does happen at 93ēC). The latest 2 times I did this with the thermostat removed. The water is still coming out blue from the petcock valve. Each time it seems like 3/4 gallon of fluid comes out. So that leaves 1/4 gallon of old content behind since the cooling system capacity is 1.03 gallons (automatic transmission). Does anyone have any idea how many such rinse cycles does it take to reach clear water? It appears to be just slightly less blue than the first drain I performed just 5 days ago. I just want all antifreeze out of the system before I use K&W Engine Block Seal.
Old Aug 12, 2022
BrotatoChip's Avatar
Super Moderator
Re: Cooling system water still blue after four rinses
Before you put any in, is your engine overheating?
Old Aug 12, 2022
niemand's Avatar
Yes. That was the reason for this undertaking. It is leaking internally. Head cannot be milled further.
Old Aug 12, 2022
engine block seal type is likely to finish killing the engine...
get a head in a junkyard, so you can still use the block
Old Aug 12, 2022
Colin42's Avatar
Whole cooling system is junk if you put that stop leak crap in. Engine too.
Old Aug 12, 2022
niemand's Avatar
Already had head milled and gasket replaced once (in 2017). Got 80K miles out of it at a cost of US$2k. Enough.
I'm rather convinced by the experiences posted here:
  1. https://www.myhonestmechanic.com/art...additive.shtml
Old Aug 12, 2022
Super Moderator
The leak stop stuff won't fix the issue anyways. Combustion gases pushing past the head gasket into the coolant. If it were the other way around, maybe.
You'd be better off buying a used engine. You're more than welcome to try that product, it is your car. Just don't get your hopes up.
eager2learn
May 30, 2017 09:18 AM
Michael Boggs
Apr 3, 2017 06:22 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
hhamin
Sep 3, 2012 05:31 AM
vickii1215
Apr 5, 2012 07:03 PM
