Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Missing coolant
Old Oct 8, 2020
Sflow22's Avatar
Sflow22 is an unknown quantity at this point
Missing coolant
Hello I have a 2002 Honda Civic with a possibly head gasket leak ? This car has never overheated and has no issues but it is losing coolant somewhere , it has no visual leaks but is looking coolant in the overflow tank , the car does not smoke or smell like burning antifreeze the top radiator is soft after it cools down and the car has no loss in power or anything , the car does have bubbles in the overflow tank when hot and the cars temp gauge takes a long time to warm up and will fluctuate all the time when driving , from cold too operating temp then too a little on the hot side ... trying to figure out my best options before doing a head gasket , what could be the other issues if it’s not the head gasket ? Thanks
Old Oct 9, 2020
BrotatoChip's Avatar
Super Moderator
Re: Missing coolant
I would be astonished if it wasn't the head gasket. If you have the tools and know how you can DIY it for $100-200. If you take it to a shop to do it'll probably be $700+.
Old Oct 9, 2020
Sflow22's Avatar
Re: Missing coolant
Alright thank you ! I’m looking into doing it , does the head always have to be decked ? Or can u get away with just cleaning it up and doing gaskets
Old Oct 9, 2020
Super Moderator
Re: Missing coolant
I have done around five head gaskets on these engines. Every time I have taken it to a machine shop to be checked, every time they have had to take off a good amount to get it flat. If you don't have a machine shop check it you're risking more head gasket issues soon afterwards.
Old Oct 10, 2020
Re: Missing coolant
head gasket.
Old Oct 10, 2020
Sflow22's Avatar
Re: Missing coolant
I have the head off and headgasket , what should I be looking for to determine it was exactly the head gasket ? I see no cracks or visual issues with the headgasket it’s self , also no places on the head or block indicating a intrusion of antifreeze ...
Old Oct 10, 2020
Re: Missing coolant
this
if you wanted to prove, engine would need to be running. testing method in the 1st post.
https://www.civicforums.com/forums/3...reference.html
wwhitby
Nov 17, 2018 11:40 AM
Slicer1989
21
Mar 20, 2018 05:21 PM
jeffinstereo
16
Jun 27, 2014 04:26 PM
pt00323i
Sep 8, 2011 01:56 PM
CBrooks
Mar 15, 2011 02:38 PM
