please confirm, blown head gasket
Old Sep 7, 2011
pt00323i's Avatar
pt00323i is an unknown quantity at this point
did the quick test.
empty overflow reservoir
fill up radiator
drive,
overflow reservoir full of coolant
after cools, radiator is low.
issue:
overheat due to lack of coolant for the last few month
other fixes done:
-Honda thermostat and radiator Cap
so I'm sure is blown head gasket, can the forum guru confirm.
thanks
Old Sep 7, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: please confirm, blown head gasket
I'd say your head gasket is shot. Any time your blowing coolant out of the overflow it pretty much means head gasket. Sorry
Old Sep 7, 2011
pt00323i's Avatar
thanks, just want to make sure, now need to decide what to do with it.
Old Sep 7, 2011
BlueEM2's Avatar
Whachya lookin at?
Fix it Do all your maintenance too, drive it for 5 more years.
Old Sep 7, 2011
pt00323i's Avatar
well I'm thinking about it, your link is very helpful. is an 99, with 185K, Auto, AC still works. So gasket set, timing belt, water pump parts will cost me $600, just few weekends, I am thinking about it.
Old Sep 7, 2011
BlueEM2's Avatar
Whachya lookin at?
Just make sure if you remove the head to get it checked by a shop. If the head is out of spec you will need to replace it with another checked head that hopefully has less mileage. After all this is done the engine should be like new
Old Sep 8, 2011
MrDobin's Avatar
MrDobin is an unknown quantity at this point
Seems solved, but for anyone else reading. Tell tale signs are bubbles in the radiator, and if you smell the oil cap and its a scent of gasoline or coolant..... done
Old Sep 8, 2011
BlueEM2's Avatar
Whachya lookin at?
Just click on my signature if you want the full story... The link that reads Overheating? Here is why.
Old Sep 8, 2011
pt00323i's Avatar
BlueEM2,
your DIY is for Gen7, fairly similar to Gen6? I've worked on BMWs and fairly good under the hood.
and Denlors KD 3970 damper holding tool is the only special tool I need?
Old Sep 8, 2011
BlueEM2's Avatar
Whachya lookin at?
It's fairly similar as long as it's a D series Someone here has a timing belt DIY for 6th gens, look it up and you will see just how similar everything really is!
mistermenphis22
Apr 3, 2016 08:06 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
arokz89
Jun 18, 2015 08:25 PM
Jun 2, 2015 11:54 AM
HondaHomer
May 14, 2015 12:24 PM
