help lol
head gasket or water pump?? i have pressure on the radiator idk if it’s exactly proper but i do have pressure and after reaching normally operating temp i get stem from radiator cap. replaced thermostat, sensor for thermostat, rad cap and i’m still loosing fluid. no leaks as far as i’ve noticed. just burning off coolant steam from cap. no nicks where the cap goes. new radiator about 6 months ago. if i open rad cap and start the car i get bubbles constantly. i can continually refill as it goes down and continues to go down. heat works fine. gauge stays right below halfway. am 100% gauge works properly. i do get a serious belt squeal every now and then which pushes me toward pump and not gasket. clean oil no milky. no major sweet smelling smoke.
Re: help lol
02?!? Surely not a 10th generation civic, it's a 7th generation civic, famous for blowing headgaskets and losing coolant through the overflow reservoir.
If you googled to search the forums, you should have been able to search the forums to find out that fact...
moving to proper section of the forums.
Read around that section before asking. saves you and us time to explain all over again.
Re: help lol
here, information. Don't post your questions in that link, we like to keep it neat. post in here after you read it.
https://www.civicforums.com/forums/331-overheating-loss-coolant-heater-blowing-cold/340759-overheating-mysterious-coolant-loss-common-causes-reference.html
we old guys are worse in searching than you young ones :P
Re: help lol
https://www.civicforums.com/forums/3...rence.htmlHere,
sirgumby1
Mar 31, 2014 06:57 PM
seahorse12
Dec 3, 2013 12:49 AM
Nox
Nov 12, 2012 07:45 PM
GFreakSI
23
Aug 25, 2010 03:36 PM
