Overheating Problem
Overheating Problem
1998 Honda Civic, The coolant goes into the overflow but will not go back into the radiator when the car is cooled off. The amount of coolant that goes into the overflow is what I need to put back into the radiator for it to be full again. I have replaced the radiator, coolant temp sensor, pressure tested it (no leaks), head gasket test (passed), radiator cap, boiled the thermostat to open and close it (pass). Mechanic also pressure tested it and head gasket checked it and both were fine he said. I let the car sit over night and the next morning I took off the radiator cap and there still pressure in the system and you could hear gurgling happening. My next thing I was going to replace is the water pump just cause it's never been done. Any ideas?
Re: Overheating Problem
Read everything in the first post of this link, and watch the second video in that post
https://www.civicforums.com/forums/3...reference.html
Oh hell I'll just put the video here for you
sdaidoji
Engine DIY
57
Nov 29, 2021 01:27 AM
eswar_ner
Oct 8, 2014 06:12 PM
seahorse12
Dec 3, 2013 12:49 AM
Nox
Nov 12, 2012 07:45 PM
gudoffer
Jan 29, 2010 09:09 PM
