Electronics Post your electronic questions here!
Horn won’t stop blowing
Old Apr 9, 2021
Frostysinco's Avatar
Frostysinco is an unknown quantity at this point
I had recently replaced a heater core on a 05 civic and now the horn won’t stop blowing when the engine is off or on idle
Old Apr 9, 2021
FRSam's Avatar
Click Here
Re: Horn won’t stop blowing
Start tracing back wires. It's probably shorting on something near where you were working
Old Apr 9, 2021
BrotatoChip's Avatar
Super Moderator
Horn relay switch wire would run through firewall in the body harness which is around the heater core. You may have cut or pinched the harness. Unplug the horn or pull the relay in the under-hood box to get it to stop. FYI, pulling the relay will also disable cruise control.
Old Apr 9, 2021
I really won’t know what to look for.
Old Apr 9, 2021
it may be pinched since I took the dash out and unplugged the wire harness to replace the heater core and o kinda didn’t know how the wire went so I did the best I could
Old Apr 9, 2021
Super Moderator
How would you like to remove the heater core again? You will need to go back in to check your work and verify the harness isn't damaged.
When pushed the horn pad in the steering wheel provides a ground to the horn relay in the under-hood fuse box. If this wire were pinched or cut it could very easily be shorted to the chassis somewhere causing the horn to always be on.
Old Apr 11, 2021
I already replaced the heater core. I went back into the car the other day to se if the wired was cut or pinched and they looked well.
Old Apr 12, 2021
Super Moderator
Remove the relay and verify the coil side is constantly grounded. If so, find why it's grounded. The wire would run from the under-hood fuse/relay box through the firewall (suspiciously close to where you were working) and up to the horn pad in the steering wheel.
Besides a damaged wire/harness from the heater core replacement the relay could be failing or the horn pad stuck on.
Old Apr 13, 2021
I’m going to check the wiring later as far as the horn pad I’m not sure if it stuck I’ve put it on three to four times already and it seems like normal. I’m going to turn the car on and press the horn or wiggle the wheel to test it.
Old Apr 14, 2021
Update so I figured it out and it was just a wire put in the wrong outlet. Now I’m havibn windows that won’t go down which is probably the same problem.
Old Apr 15, 2021
windows are usually tied to broken wires at the door hinges.
check that first
how did the connector end in the wrong outlet?!?
justinakaparker
Jun 6, 2018 08:21 AM
DeX
Sep 12, 2013 01:10 PM
wontonamo
Nov 8, 2007 12:18 PM
karizzle
Jul 11, 2006 08:38 PM
astr033
Jun 5, 2003 07:02 AM
