Issue with engine have spenta lot of momey still wont get fixed
Old May 29, 2025
Taimour's Avatar
Taimour is an unknown quantity at this point
Hi guys,
I have a 2005 civic ex automatic. I bought it last summer as my first car.
So the problem with this car is that it drops the Rpm to around 500 and the engine shakes at low rpms. Sometimes it stops and speaciialy if you put the ac on at idle it will start to rattle
Last time i got it checked and it seemed thst the oil wss getting into the coils so i changed the coils the valve cover gasket the o rings for spark plugs etc. And it got good.
Then what happened that the water pump leaked and i needed to get it changed. So they open the valve cover then the timing cover and changed the water pump.
When the mechanic was tightening the valve cover , he accidentally tightened it too much that the screw holding end on the cam got ripped off. I got it fixed with silicone since i couldnt get it done right costs too much money.
Now the car again has the same issue and wont stop doing it. This time there is no oil in the coils no issue with the valve cover gasket and i really dont know what to be done here.
Note that there is no engine light. No trasmission light the oil is on perfect level still with would do the same thing over and over again
Can anyone help
Old May 29, 2025
chozobody's Avatar
chozobody is an unknown quantity at this point
Re: Issue with engine have spenta lot of momey still wont get fixed
First check for vacuum leaks. Sounds like air could be getting in where it shouldn't.
Old May 30, 2025
Colin42's Avatar
Could be the iac
Jenndenise41
Nov 15, 2018 09:10 PM
IrishTexan
Jul 31, 2018 10:54 AM
GregS
Mar 9, 2014 12:00 AM
TINOO
Jul 10, 2010 10:13 AM
kryngle
Mar 19, 2010 06:54 PM
