Nut identification
Old Feb 4, 2025
moms7thex's Avatar
moms7thex is an unknown quantity at this point
Nut identification
When changing the oil, found this nut under the driver side of engine. I could not find a bolt on the engine that it may match up to but saw the same nut used on the engine. Any ideas? I have not disassembled any parts that use this nut.
thanks
Old Feb 4, 2025
Re: Nut identification
Check suspension components. that's the only thing I can think of that would use a flanged nut like that. Maybe exhaust flanges?
Quick question, is that a 10 or 12mm nut (or.. other size)? Would maybe give a better indication.
Old Feb 4, 2025
moms7thex's Avatar
Josh, Thanks for your reply. It is a 12mm nut and I can see that it is also used on the brake line unit, power steering, and couple other places visible from above. I am hoping that it was just sitting on the frame or wind baffle under the engine, maybe from being dropped there from a repair in the past...
I'll look around underneath during my upcoming pcv valve cleaning.
Dave
Old Feb 4, 2025
Check some of the bracketry/manual tensioners for the alternator, ps pump, or AC compressor
KurtS
Transmission
Apr 17, 2022 08:15 AM
Millsy088
Transmission
16
Dec 29, 2021 12:41 AM
Niaboc67
Mar 16, 2016 08:41 PM
manfredww1
Jul 14, 2015 10:24 AM
WaryDriver
Dec 31, 2011 12:00 AM
