running issues stumped and no-one seems to know [solved]
Old Apr 14, 2023
2civic's Avatar
2civic is an unknown quantity at this point
2001 civic a2 engine
I start car from cold run it to hot drive 30min no problem runs like it always had
shut it off for hour and start it it runs for a couple minutes then goes into a "limp" mode it doesn't have a miss but doesn't have power and wont hardly idle
i can shut it off and 10 to 15 minutes later it drives fine again
during that time fuel pressure is same and proper
i pulled o2 sensor out and it ran same
I cleaned egr same
changed throttle assembly which included 4 sensors idle air throttle position sensor and 2 more same running
compression all same and good
swapped all 4 coils from running car same running issues
I changed cam position sensor
Old Apr 15, 2023
Wankenstein's Avatar
re: running issues stumped and no-one seems to know [solved]
Have you tried swapping in a known properly functioning ECU?
Any CEL codes?
These might help
https://www.civicforums.com/forums/3...ode-p0132.html
https://www.civicforums.com/forums/3...-included.html
Old Apr 15, 2023
2civic's Avatar
i have been wondering about computer i will see if i have one to try
thanks
Old Apr 15, 2023
thanks
yw.
In the links I provided you will see replies by Ezone. He doesn't reply much here in the past couple years. He is a long time Honda dealership mechanic and has helped countless numbers of people with their Honda's. So, you may want to search his threads/replies related to your car's issue(s).
Old Apr 16, 2023
2civic's Avatar
thanks
I went on that web site
Old May 11, 2023
2civic's Avatar
i changed computer and ignition switch it had new problems BUT i checked codes again and it told me cam position sensor
i changed it and drove it one day so far and no running issues maybe i got it thanks
Old May 11, 2023
Re: running issues stumped and no-one seems to know [solved]
faulty or fried ECU's are usually caused by loose alternator bolts, check all of them holding it to the engine
https://www.civicforums.com/forums/440-ecu-fried
Old May 11, 2023
Colin42's Avatar
Hope you used an oem sensor
Kaneboys03
May 28, 2022 08:12 AM
CivicChoice
Idle Issues
38
Oct 17, 2021 06:18 PM
NJKirchner
Lighting DIY
Dec 12, 2020 07:05 AM
d0wnShiFt
May 1, 2011 04:40 AM
Bires
Dec 2, 2004 01:01 AM
