Excessive oil consumption
Old Oct 6, 2022
MrMilitary's Avatar
MrMilitary is an unknown quantity at this point
Good morning. 2003 Honda civic sir 2.0 k20a3 125k on it
I add oil very week. Probably 1/4 to 1/5 of the dip stick weekly
my garage floor has no oil drips
I smell oil when I come to a stop or reverse. Not when I'm driving steady. It's burning oil but where?
suggestions on what to check or do?
I drive it hard daily all the time cant help it with the k/n cold air intake at high rpm. She sounds delightful 😊
Old Oct 6, 2022
BrotatoChip's Avatar
Super Moderator
Re: Excessive oil consumption
Possibly leaking from valve cover gasket onto the exhaust, then burning off? Take a look at the engine, there should be evidence somewhere.
Old Oct 6, 2022
have you looked behind when driving? You might be spreading a smoke screen and making the cars behind you crash
Old Oct 6, 2022
Serious note, might be burning in the cylinder (i.e. leakage past the rings). Leakdown test might not be a bad idea
p.s. see if you can gauge how many km it takes you to add a liter. I forgot where I read this, but something like a quart every 1000mi (or was it a liter every 1000km) was acceptable oil consumption. You are taking those dipstick readings on level ground, right?
Old Oct 6, 2022
MrMilitary's Avatar
400 kms a tank 1 tank a week ish adding oil each week ish. I'll look into that leak down test and might have a look at the engine gasket. (I think thats what it's called)
Yes when I check the oil she's on the ground no car jacks 4 tires touching
Old Oct 7, 2022
Super Moderator
According to Honda, yes. According to literally anyone else, no.
I was assuming the rings were okay because the engine only has 125k km. They could still be bad though.
Old Oct 7, 2022
GolNat's Avatar
Prelude Owner
I have to add a quart every 200-300 miles on my Prelude. It’s needs to be rebuilt but it’s cheaper to keep adding oil to it for the time being.
Old Oct 10, 2022
Super Moderator
That is quite the oil consumption. I hope you're using cheap oil
Old Oct 11, 2022
GolNat's Avatar
Prelude Owner
Lol oh yeah. Cheapest Dino oil I can find. Amazon or Walmart typically. I’m pretty sure I can just change the filter at my next oil change interval because none of the original oil is in it still.
thesupersoap33
Apr 9, 2020 03:43 PM
Inkedmechanic
Apr 29, 2017 08:37 PM
kimfromcali
Jul 11, 2011 05:53 PM
sik92civic
Feb 18, 2010 07:00 PM
2000civic00
Dec 5, 2008 04:29 PM
