Engine Smoke after vehicle was idle for a few years
Old May 20, 2022
ktong's Avatar
ktong is an unknown quantity at this point
Hi Everyone,
Hoping someone can give me some guidance. My 2003 Civic LX has been sitting in my garage for about 3 years, I decided to get it back up and running. Haven't done any maintenance during that time. When I started the vehicle, smoke was coming out of the engine. I asked my friends, they say it should be normal because the Oil hasn't been changed for a long time, plus some built-up dust. Check the fluids for the power steering, engine oil, coolant, and brake fluid, It all looks normal. I could top up the engine oil. I played it safe and turned off the vehicle because I was worried about the smoke. Need to know if it's a good idea to restart the vehicle again and keep it running for a while to get things moving. Appreciate the help, thanks!
Circle area is where smoke was coming out.
Old May 20, 2022
BrotatoChip's Avatar
Super Moderator
Re: Engine Smoke after vehicle was idle for a few years
Maybe oil burning off the exhaust manifold? It looks like it needs some maintenance for sure.
Old May 20, 2022
with that much oil spread out on the surface, it is going to smoke... Clean it first.
when removing the cover, check if no damaged wires
Old May 20, 2022
Colin42's Avatar
Normal from it sitting looks like it needs a new valve cover gasket though
rogerscivic
27
Sep 1, 2018 10:00 AM
aeraiva
Oct 15, 2012 11:41 PM
ashosheh
Mar 4, 2010 05:46 PM
JUSJEN517
Apr 5, 2006 06:54 AM
