Gen 7 stripped valve cover hole [solved]
Old May 17, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
So ya. Thought I was seating the valve cover all nice. The rear left (facing the engine) screw just went pop and that was it. Would t catch again.
I have a heli-coil kit, and see some threads saying they are used on heads. I figure I can do it for the valve cover. Opinions please??
I am amazed at how easily these aluminum blocks and heads strip out. I don’t remember these issues in the old days.
Old May 17, 2022
Colin42's Avatar
re: Gen 7 stripped valve cover hole [solved]
So you stripped the hole in the head for the valve cover bolt?
you can helicoil it, just be careful to not get any metal bits in the engine
Old May 18, 2022
BrotatoChip's Avatar
Super Moderator
You didn't just break the bolt, did you?
Old May 18, 2022
crajnai's Avatar
7th Gen Victim
No. Bolt is just fine.
Old May 18, 2022
crajnai's Avatar
7th Gen Victim
Update. Helicoil works! Had to put in two of them but worked great. Impressed my buddy who never used them and was quite skittish.
car is running! Finally!
Old May 20, 2022
Wankenstein's Avatar
Re: Gen 7 stripped valve cover hole [solved]
Originally Posted by crajnai
Update. Helicoil works! Had to put in two of them but worked great. Impressed my buddy who never used them and was quite skittish. car is running! Finally!
Helicoils work very well as long as they don't get much use. They don't hold up well for bolts that get removed and reinserted often.
A Timesert install is better in a repeated use situation. However, Timeserts are much more expensive.
Old Sep 22, 2023
DC EK's Avatar
DC EK is an unknown quantity at this point
What would likely happen if too many shavings landed in the engine?
Old Sep 22, 2023
Shavings could get caught in places they shouldn't be. If, by some chance, it made it between a bearing and the surface that rotates within said bearing, could lead to damage or premature wear.. Ideally, the oil filter would pick it up or it'll come out with an oil change. If you forgot about dropping a good amount of shavings into the engine and you saw it in an oil change (or a tech saw them in an oil change), you (or they) may freak out thinking your engine is broken. Moving slowly and vacuuming up any metal chips is always going to be the safest bet.
CivicRider
48
Jun 1, 2021 06:41 AM
pottedgold
Feb 13, 2020 10:28 AM
Jenndenise41
Nov 15, 2018 09:10 PM
stevelaw18
Jun 13, 2011 08:04 AM
Arcan3
Jul 31, 2004 05:24 PM
