Replacement cam sensor
Old May 10, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
I got the denso crank sensor but the cam sensor (TDC) is out of stock everywhere.
Has anyone had luck using aftermarket sensors for the cam? If so please advise brands that actually work.
Thanx
2003 Civic EX coupe
Old May 10, 2022
Colin42's Avatar
Re: Replacement cam sensor
No, either get one from the dealer or try your luck at the junkyard
Old May 11, 2022
crajnai's Avatar
7th Gen Victim
Ok. Should I not bother with it if it is not failing then? How durable are these things? The one on there looks basically ok and has not thrown codes.
Old May 11, 2022
FRSam's Avatar
Click Here
If it isn’t throwing codes, there’s no need to replace it.
Old May 11, 2022
BrotatoChip's Avatar
Super Moderator
Are you having issues that made you want to replace it?
Old May 11, 2022
crajnai's Avatar
7th Gen Victim
No issues. Just have it all apart now figuring on preventing a future issue.
Old May 11, 2022
FRSam's Avatar
Click Here
Cam sensor’s easy to get to anyway. I wouldn’t replace it until necessary.
Old May 11, 2022
Colin42's Avatar
If it ain't broke don't fix it
ron36535
Nov 9, 2018 07:39 AM
justinakaparker
Jun 13, 2018 03:31 PM
colephillips08
Feb 23, 2015 07:48 PM
sleepy-racer
Buy, Sell, & Trade - Archive
Mar 1, 2007 08:47 AM
