Camshaft PS P0344
Old Jun 5, 2018
justinakaparker's Avatar
justinakaparker is an unknown quantity at this point
Camshaft PS P0344
So I have a camshaft position sensor a circuit will that cause all cylinders to miss fire. I just changed timing belt, cam pos sensor, plugs and ignition coils. On my way to work and car would Rev over 3000 rpm did it all way home (about 100 miles). Decide to take my car to auto zone to put on tester and I got all those reading's but later my car ran fine? Rev over 6000 and everything I just have the base 1.7 04 civic lx
Old Jun 5, 2018
Re: Camshaft PS P0344
Make absolutely sure the connector for the cam sensor is actually plugged in all the way and latched
Was a genuine Honda cam position sensor installed, or was it an aftermarket part?
Old Jun 5, 2018
factory
Old Jun 5, 2018
Slumpertcivic's Avatar
Those cam / cank sensors seemingly are very susceptible to dirt / moisture / blue moon on tuesday ECU issues.
Highly suggest unplugging the sensor and giving both the connector and the sensor a good shot of electrical contact cleaner or MAF cleaner and let it dry. Be sure to listen for the click when reconnecting it.
Old Jun 6, 2018
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
May seem random but did you loosen your alternator and bolt it back down tight?
I had a similar issue after doing the same maintenance where the car drove fine but under hard acceleration the cam sensor would through a CEL and put the car in limp mode. Ended up blowing the ECM and was a major pain in the butt.
Old Jun 6, 2018
^That's a good point.....
If the sensor code sets right away and quickly, you could unplug the alternator to disable charging and see if the code stays gone...at least that might indicate the charging system has something to do with it
Longshot, but worth a try
Old Jun 8, 2018
okay so i changed the camshaft sensor, now my CEL is still saying its that sensor misfire on all cylinders and something about cylinder bank 1 overheat? now im driving and my whole car will jump then it goes into limp mode ( cant rev over 3500) but if i turn it off while im driving wait 5 sec turn it back on it goes off limp mode but about 5 min later it will engage again. does that sould like it could be my ECM or like possitive because its not cheap and i about bought a used engine because its doing that. never heard of limp mode before yesterday. or is there a way to disable limp mode because its not driving rough or anything until limp mode activates. I tried unpluging my battery for 12 hours i tried pulling my fuse for ecm. nothing new. also yes i have replaced my altinator all my plugs ignition coils crank and camshaft sensors fuel pump and im just tiered of buying new parts. do you think my ecm could cause all those codes to be
Old Jun 8, 2018
The computer can run in limp mode based off the crank sensor. Due to the less trigger signals from the crank vs the camshaft it will not rev very high to prevent timing errors.
You need reliable camshaft signals to run properly.. Some camshafts wear down and move in and out enough to cause a sensor issue as well as sensor itself going bad can shows up as it warms up.
Very common we see people posting their aftermarket version didn’t help and almost never do we hear about the dealer one being a dud.
Old Jun 9, 2018
P0344 CMP sensor a intermittent
Help please I just changed my camshaft sensor, crankshaft, ignition coil's , plugs , altonator (sorry auto isn't working). I was driving now if I let my car stay under Rev 3000 it will put its self in limp mode (can't Rev over 3500 and sluggish response) cleared my codes and just checked them I have
P0344 - CMP SENSOR A INTERMITTENT
P0300-4 Cylinder 134 misfire detected
P0134 H02S S1 CIRCUIT HIGH VOLTAGE/NO ACTIVITY
Old Jun 10, 2018
Do a terminal tension check on thee CMP plug
Goggle search "how to do a pin drag test"
Old Jun 11, 2018
P0344 cmp sensor a intermittent
i know this was on my last thread but i did all and just trying to get more people to help me out thanks to everyone who did try tho.
Old Jun 13, 2018
Exclamation timing belt and camshaft sensor
okay so if you seen any of my other post im having huge problems with my camshaft sensor. its saying camshaft sensor intermittent so i decided to it back of too discover my timing belt is loose. probably timing belt tensioner idk about to change that this weekend and im just curious could that cause my camshaft sensor to read that or say its bad ? and if anyone knows how to fix camshaft intermittent problem let me know thru here if you dont get what i mean ill post a link to a video on what im talking about just badly need help only transportation for now.
Old Jun 13, 2018
BrotatoChip's Avatar
Super Moderator
Re: timing belt and camshaft sensor
If you're timing belt is loose I hope you're driving it at all or you're asking for trouble. If it is loose it could've easily jumped time by a tooth or two. It wouldn't run well but it would still run, that would throw a fault for camshaft or crankshaft, can't remember which. I wouldn't worry about troubleshooting that until you replace the timing belt/tensioner/water pump.
Old Jun 13, 2018
yeah im not driving it, i believe it already jumped time missing on all cylinders but thanks no problems with my crankshaft but camshaft one day says its not working next says sensor intermittent
ron36535
Nov 9, 2018 07:39 AM
Secola
Feb 27, 2018 05:34 PM
colephillips08
Feb 23, 2015 07:48 PM
floyd107
Feb 6, 2011 03:29 PM
sleepy-racer
Buy, Sell, & Trade - Archive
Mar 1, 2007 08:47 AM
