Please help. Finally found something out of place.
Old May 5, 2022
Nicoallgaier's Avatar
Nicoallgaier is an unknown quantity at this point
car won't turn over. This is all I found on my own. I'm not the most car savvy individual but I've always done my own work. I don't know it this is the cam shaft pulley, harmonic balancer, or what. I would appreciate any help I could get as to how I replace this. YouTube link would be sooooo helpful.
Old May 5, 2022
BrotatoChip's Avatar
Super Moderator
Re: Please help. Finally found something out of place.
Looks like the camshaft pulley. How did you manage to do that? It would be best to do a timing belt job and replace the pulley while the belt is off. There are DIYs on here somewhere.
Any fault codes? I wonder if that missing piece fell down and damaged the crankshaft position sensor which is why it won't start.
Old May 5, 2022
Colin42's Avatar
Broken cam pulley, not good. Hopefully the broken chunk only damaged the crank sensor.
new timing belt, tensioner, and water pump. If the crank sensor is damaged only buy an OEM one
Old May 5, 2022
also check if coolant reservoir is full - if it is it will also need to do a head gasket change (easier to do during timing belt change).
buy only OE sensors, denso are them
Kendeetz
General
May 4, 2022 07:15 AM
crash_x
Apr 29, 2018 03:02 PM
TransformedBG
Mar 2, 2006 10:00 PM
AZ2K1Civic
Arizona
20
Sep 4, 2004 07:30 PM
SaiyanMatador
Bolt-on Engine Performance
Sep 16, 2002 10:03 AM
