Idles after ECU reset until next car start
Old Mar 5, 2022
  #31
BlazeCode's Avatar
BlazeCode is an unknown quantity at this point
Re: Idles after ECU reset until next car start
Originally Posted by sdaidoji
Just to be sure, in US and Si model, so you have a hatchback?
yep! 2004 Honda Civic Si Hatchback 2.0L.
I ended up finding a tiny crack on the nipple of the EVAP Purge Valve on the TB. That combined with the CIL Code before saying that valve was stuck open made me think it was causing a vaccum leak. Took the EVAP Purge Valve off and plugged the hole with my finger. It FINALLY stopped bouncing the idle!!! So I ordered a new one thats coming in a few days. For now I wont drive it i guess. However, even when the idle doesnt bounce its staying at a steady 2,000 RPM(thats what it was bouncing up to before.) Could it be as simple as doing a TB Relearn procedure ive read about to get it to learn how to idle without the vacuum leak now?
Old Mar 5, 2022
  #32
Colin42's Avatar
Originally Posted by BlazeCode
Id like to rule other stuff out hopefully before spendiing a couple hundred on another OEM IACV.
that's why I said this
Originally Posted by Colin42
Don't buy an aftermarket one, grab one out of a junkyard if you don't want to buy new oem
Old Mar 5, 2022
  #33
glad one cause has been found
one thing at a time, fix that and see where it lands
Old Mar 14, 2022
  #34
BlazeCode's Avatar
FINALLY got the part and installed it today. It idles lower, but its still bouncing. Gonna replace the IACV and TB gasket tonight since I ordered those too. Ill reply with an update later.
Old Mar 15, 2022
  #35
BrotatoChip's Avatar
Super Moderator
Is it an OEM IACV?
Old Mar 16, 2022
  #36
BlazeCode's Avatar
Is it an OEM IACV?
im not 100% sure how to tell, but it looks like it based on what I see. Reguardless, it fixed my issue. I appreciate all the info! Thanks guys!!
Old Mar 16, 2022
  #37
oh, so they worked? Good!
basementx
Nov 10, 2021 01:01 AM
atkinson40
Apr 1, 2014 08:59 PM
95civic123
Nov 3, 2011 11:53 PM
babyontheway
Sep 19, 2008 09:56 AM
ponyman
Dec 12, 2004 04:03 PM
