AC doesn't cold after Heater been active
Old Dec 4, 2020
ernest64xp's Avatar
ernest64xp is an unknown quantity at this point
Exclamation AC doesn't cold after Heater been active
Hi Guys again, you might remember me from a previous thread i initiated before about my Temp Gauge going crazy and start-up problems. I've been having for the most part issues with overheating as its common on our vehicles, so usually what I do whenever I have an overheating issue is turn the Heat blower to circulate the hot air outside the cabin and it usually works like a charm... But it leaves a nasty issue behind... Once that the car stops Overheating and I check and fill the coolant reservoir, the AC Unit just simply wont blow cold air of it until next day, or at least 12 hours after overheating occurred... Why would that be, is the Heater core valve stuck, or should it be the Thermostat?
Thanks in advance for all of your help!
Old Dec 4, 2020
Re: AC doesn't cold after Heater been active
Fill the radiator first.
Old Dec 4, 2020
ernest64xp's Avatar
Yes, I forgot to include that I also fill the radiator and coolant reservoir when the engine stops overheating... It just intrigues me that AC doesn't blow cold air after all of that is being filled up afterwards but before using the AC Again.
Old Dec 4, 2020
most likely need to fix the headgasket.
test method described in the first post... Two videos
https://www.civicforums.com/forums/3...reference.html
Old Dec 8, 2020
BrotatoChip's Avatar
Super Moderator
This could be unrelated as well. A/C compressor clutch air gap may be too large causing slippage and overheating. Compressor would go into a thermal lockout until it cools off (multiple hours).
As others mentioned focus on the overheating issue before looking at the A/C.
willysp
Interior
34
Feb 11, 2019 08:19 AM
316
Interior
17
Dec 12, 2015 06:54 PM
alex_nyc
Jan 17, 2015 03:35 PM
jmtikhonoff
Feb 10, 2013 04:17 PM
webster426
Air Conditioning
28
Jan 7, 2012 12:27 AM
