HELP! Cylinder misfires and need to drive 2,000 miles with no other options
Old Jul 16, 2020
CivicPo301Gang's Avatar
CivicPo301Gang is an unknown quantity at this point
Hello, I have to drive 2,000 miles and have no money, period. I have a cylinder 1 po301 and cylinder 2, po302 misfire. I changed the crankshaft position sensor and still misfires. I have a car at my house. What is tips to get my car to make this trip. I’m junking it when I get home... or how do I make this trip. Idk what to do. Will it make the trip misfiring
Old Jul 16, 2020
FRSam's Avatar
Click Here
Re: HELP! Cylinder misfires and need to drive 2,000 miles with no other options
Hard to get 2000 miles without money for gas...
Assuming you can do some diagnosis, you can narrow it down to coil pack/spark plug/beyond. Diagnose by swapping plugs/coil packs into different cylinders to see if the code follows. If it’s plugs, they’re like $9 each, just replace them. Don’t bother with coil packs; they’re a little more expensive. Either way, it *should* get there without much of a problem.
Old Jul 16, 2020
I just changed the plugs and coils 2 months ago... will check again tho
Old Jul 16, 2020
FRSam's Avatar
Click Here
Did you buy crap aftermarket coils?
Old Jul 16, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
And use only OEM NGK spark plugs. NO BOSCH or cheapies.
Old Jul 17, 2020
easy item to check. check your coolant overflow reservoir.
If empty, you might be having a leaking head gasket.
While running, it will push burnt gases to the coolant side and coolant out of the reservoir, but overnight coolant seeps into cylinders and foul plugs, causing some misfires.
I had that issue when my headgasket had a small leak.
Nitrozx10
Feb 27, 2020 01:25 PM
civicbaby
Sep 7, 2011 07:16 PM
civicbaby
Sep 7, 2011 04:55 PM
NJPiineapple
Jul 26, 2011 11:20 AM
terrapin893
Dec 29, 2009 06:11 PM
