Engine light is coming on and going off.
Huckin' Hippie
I read the code - o2 sensor position 1 no response. It doesn't seem to be effecting performance in any noticeable way. I figure the sensor will have to be replaced so what I'm wondering is this, this is in my 2005 SiG ( Canadian Coupe) I also have my older 2002 DX which has a stock 1.7, but the SiG has the V-Tech SOHC 1.7 and I believe the Cat configuration is different in the models. Can I use the o2 sensor in the 2002 DX in the 2005 SiG?
Re: Engine light is coming on and going off.
1.7 engine? between the years you said the Primary sensor is not interchangeable.
04 and 05 use a AF sensor instead of plain o2 sensor on primary location
MichaelEB
18
Jul 26, 2014 10:33 PM
AndrewLA
Oct 26, 2011 08:06 PM
twistedslim
Jan 18, 2011 09:49 AM
ostetco
Jan 6, 2010 04:37 PM
