up stream O2 sensor.. am I losing my mind?
Old Aug 2, 2017
MainFrame's Avatar
MainFrame is an unknown quantity at this point
My wife has a 2005 Honda Civic (not sure which trim.. the cheap one, automatic transmission, 1.7L, no power anything). At about 105k miles it started throwing the code for the up stream O2 sensor (bank 1 sensor 1). I tested the heater circuit (blue plug, black wires, sensor on top of the manifold) with my DMM and sure enough it was dead. Went to O'Riley's and they had the OEM sensor listed as a Denso 234-9017.. but of course they wanted $320 for it. So I looked around online, made sure I had found the right sensor, Denso 234-9017 (around half the places I looked had the down stream sensor listed as the up stream sensor).
Sensor shows up with the longer wire, two mounting brackets, and grey plug identical to the down stream sensor. The sensor with the blue plug has a male connection on the end.. the Denso 234-9017 has a female connection on the end. I have looked at several tutorials on line showing replacement of the sensor on top of the manifold, blue plug, then the pictures of the sensor they say to replace it with (Denso 234-9017) has the grey plug.. super frustrating.
What gives? Is this the down stream sensor, even though everywhere I look says it's up stream? Are there different sensors for different trim models that I don't know about? I figured this would be an easy task, but I guess I must have missed something..
Old Aug 2, 2017
04 blue civic's Avatar
04 blue civic is an unknown quantity at this point
Re: up stream O2 sensor.. am I losing my mind?
Yes they do mount different diff models. I.e. Coupe sedan, etc.
Mine on my sedan is not in manifold but in from pipe right under the manifold.
I'm assuming your convertor is made into your manifold and that's a different sensor.
Go to majestichonda.com input your VIN and it will give you the correct oe part number
Old Aug 3, 2017
Plain Jane car is LX or DX, no VTEC, and engine code D17A1, the upstream sensor is an AF (air/fuel ratio) $en$or-- not standard O2 (even though the look alike, they are very different internally)
Look up your car here on the DENSO website:
http://densoautoparts.com/find-my-part.aspx
Straight from the horses mouth:
Denso #234-9005
Old Aug 3, 2017
MainFrame's Avatar
Denso #234-9005
Ugh.. alright. That sensor has the right male connector on it (and the wire looks to be the right length). Looks like I'll be contacting the Amazon seller for an exchange.. on the up side, this sensor is $15 cheaper.
Old Aug 3, 2017
Try Majestic Honda they're reasonable. Maybe cheaper maybe not but worth a shot
Old Aug 13, 2017
MainFrame's Avatar
Now I want to make sure I've got the right thing here, because Majestic has the sensor, part#36531-PLM-306, listed for $207.. but on Amazon Denso 234-9005 is only $95 with free shipping. That's quite a big disparity in Price. To the point that I would think the Denso on Amazon might be a knock off, except for the fact that it has great reviews, and so does the seller (3rd party).
Coming from the turbo Subaru world I'm used to O2 sensors not being cheap.. but I always attributed that to them being subject to much higher EGT and manifold pressures than you would see on a N/A engine.
Old Aug 13, 2017
Link?
Maybe the seller isn't actually selling true Denso brand, but are selling cheapass parts that only cross reference to that Denso number.
DangerZone sells it for $159.99
Advance $158.99
Napa is proud of it, 171.99
Pep Boys $125.59 https://www.pepboys.com/product/details/806611/00504 (link)
Old Aug 15, 2017
MainFrame's Avatar
https://www.amazon.com/Denso-234-9005-Oxygen-Sensor/dp/B000C5UFVM/ref=sr_1_2?ie=UTF8&qid=1502815146&sr=8-2&keywords=Denso+234-9005
It's the same seller who I got the other sensor from, which appeared to be in genuine OEM packaging. With the seller rating and part reviews I'm pretty sure it should be the real deal.. but with such a price difference I feel weary about it.
The photo Amazon is using has a gray connector, not blue, but that's not the seller's photo, and it's not uncommon to use a generic photo, so that might not mean anything. Plus the manufacturer could have changed the in the last few years for whatever reason.
Old Aug 15, 2017
Wait..... Don't you understand DENSO IS the manufacturer? (Denso is short for Nippondenso)
Did you check/click the Pepboys link I posted above?
Old Aug 15, 2017
Wankenstein's Avatar
In the past five years I've purchased two Denso o2 sensors (6th & 7th gen) from Amazon that both work fine and cost less than the Honda Genuine..a.k.a NTK/NGK/Denso.
I recently purchased a Denso 234-4099 through Walmart online for $30 and it's stamped manufactured in USA. The Honda Genuine is listed at $225.
Not sure if Denso made in Japan o2 sensors are available in the US anymore?
Old Aug 15, 2017
I don't care where a Denso part was made as long as it is a genuine Denso part.
https://www.denso.com/global/en/
Same for NGK/NTK
https://www.ngkntk.co.jp/global/
https://www.ngk.de/en/company/the-ngk-corporate-group/
Old Aug 16, 2017
MainFrame's Avatar
Yes.. Denso is the manufacturer, but just because the manufacturer hasn't changed doesn't mean that they are still making the sensor with the exact same color scheme as they did 12 years ago. Even if it's the same exact part, from the same manufacturer, sometimes you will see slight variations between years..
Are you saying that if it doesn't have the same blue connector as what they made 12 years ago that it must not be genuine? I looked at your link, and that sensor also doesn't have the OE color scheme..
Old Aug 16, 2017
No, I'm saying I seriously doubt Denso would sublet building their sensors to some other 3rd rate company.
AFAIK they haven't sold out like some other well known brand names who were bought out so someone could capitalize on the name while selling absolute crap wares until the name is completely ruined
Old Aug 16, 2017
MainFrame's Avatar
Ahh.. yeah, I get that.
I guess I'm gonna go ahead and order that one from Amazon.. not expecting any more problems at this point.
Old Oct 15, 2018
llbaker2's Avatar
llbaker2 is an unknown quantity at this point
The CEL on my Honda 2005 Civic LX recently came on. Got a sensor tool and checked. Got P0135. Said something like "Bank 1, Sensor 1 heater malfunction", dont remember exact quote. Checked continuity on heater (two black wires) and got zero. Pulled the sensor and noted that it was Denso 192400-1160. Started looking for replacement. Was not able to find exact match. Read someplace that that sensor had been discontinued. Checked Honda and found replacement with crazy price (nearly $300). Went to Denso web site and found replacement part 234-9005. Did some Googling and found an extremely wide price range on Denso 234-9005. Saw prices from $16 to over $200 for what sellers advertised as Denso 234-9005. Did a little more Googling and saw that my Civic required a wideband sensor, a more expensive type and that it was an air/fuel ratio sensor as apposed to a normal O2 sensor. Dont know what wideband means or AF sensor vs. O2 sensor difference other than the former being more expensive. Dont understand the huge price range for what is advertised as being the same item (a range of nearly 10x). Cheapest were listed on eBay ($16). Dont remember where I saw the priciest. Only thing I can figure the cheaper ones must be knockoffs. Needed car so decided to pick up sensor from AutoZone for $159. Think the same could have been picked up for $115 off Amazon. Dont know, may have pissed away lots of bucks for a part that could have been had for much less. Read several stories of people going the cheap route only to have new sensors fail in a relatively short time. I went with the AutoZone version assuming the cheap online versions were knokoffs. The replacement look to be the same except for color of the plug (original was blue, replacement was gray). My CEL is now out. Have only driven about 30 miles since replacement but so far so good. Guess time will tell.
Old Oct 15, 2018
llbaker2's Avatar
Think you are comparing apples and oranges. The original AF ratio sensor in my 2005 civic LX sedan was labeled as DU2 Denso 192400-1160, which appears to have been discontinued. The Denso replacement is 234-9005. Technically the 192400-1160 and the 234-9005 are two different parts. No big surprise that the plugs are different colors. Plugs look to be shaped the same, just different colors. It seemed to work for me. Only put about 30 miles on since replacement so a little early to say. Time will tell. Got mine from AutoZone not Amazon.
Old Jan 12, 2025
dashxdr's Avatar
dashxdr is an unknown quantity at this point
I have been struggling to get my 2005 Civic to pass smog for just over 1.5 months now and of all the things I tried and O2 sensors I bought + returned this posting was the one that had the magic and saved me. The essence of the problem was the heating element of my upstream AFS (Air/Fuel Sensor) burned out and this caused the initial check engine light problem (P0135). So many E-Bay sellers and even Amazon sellers will tell you they have the correct part and at prices from $13 to $40 (of the ones I tried) but they are either wrong or lying. The fact is the Air/Fuel sensor is a different beast from the heated O2 sensor, it is more complicated and more expensive. I ended up solving my problem with the 235-9005 part from Autozone for $192.99 (January 2025 timeframe). I'm sure I could have gotten a working part for maybe $110 less online but I was exhausted with failures so I decided to reward Autozone's brick + mortar presence and keep the part.
BTW the part number inscribed on the AFS from Autozone (their part # is 234-9005) is:
DENSO [NEW REPLACEMENT PART BOUGHT JAN 2025]
Assembled
in USA
192400-8040
11008
Maybe that will help in someone wanting to buy a cheaper equivalent part.
My original failed AFS (open circuit heating element) is this:
DU2 [ORIGINAL 2005 PART]
DENSO
192400-1160
O6G22
Along the way to diagnose the problem I went through 2 different OBDII testers from Harbor Freight, they're up to some scam of their own. An ELM327 bluetooth sensor you can pair with your smart phone can be had for $5 or cheaper, free shipping, and with a little patience you can do anything that any of these expensive scanners can do. Harbor Freight's scam seems to consist of selling you the $30 option, you find out you need more features so you return that (paying the 20% restocking fee) and get the $60 option, which has more features but still not good enough, so you keep upgrading, paying 20% restock fee each time until finally maybe for $600 you have the scanner that can do everything you need. Meanwhile you can buy something on E-Bay for $30 that is a much better value. Shame on you, Harbor Freight! The added features don't cost them any extra, it's just more functionality built into the software + the hardware is the same.
I only tried the $30 and $60 scanners from Harbor Freight but they gave me enough insight as to what I wanted to be able to do through the OBDII port. I returned them and ate the $18 restocking fees and considered it a good expense for tool rental. I'm an engineer and so I made a gadget using a 3.3V serial port USB adapter, 2 BC547 transistors, a diode, and 5 10K resistors. I use the FTDI based usb adapter using libftdi on linux (as opposed to /dev/ttyUSB0) and use the RTS line to send the 5 baud 8N1 0x33 byte to get the car's OBDII link to activate (ISO9141-2 protocol) and I was in business. I wrote code in 'c' and node.js to drive the serial port using libftdi and maintain the link, and I queried the 12 live data values available (two of them return 2 values) so I can plot 14 different readings in real time with a sample on each taken every 1.92 seconds. See the attached image.
What I learned is how to determine when an ordinary heated O2 sensor (HO2S) is installed in place of an air/fuel sensor (AFS). There are two driving sessions shown in the image, the left one is with an H02S installed (incorrect part) going from a cold engine start to when a P1172 error fault is thrown. The right one shows an already warm engine driving session with the correct AFS installed. Both are for the upstream side (before the catalytic converter). The key thing to observe is the O2 B1S1 mA current reading (label has 0x34.1) and the O2 B1S1 LAMBDA reading (label has 0x34.0). An HO2S just used the heating coil to warm up the sensor, the polarity of the voltage applied makes no difference. For an AFS the polarity is everything, the ECU uses the applied current to regulate the "sweet spot" of the AFS so as the air/fuel ratio changes the ECU can get a good reading... that's the limit of my expertise on it. The point is that the ECU when it puts a current on the heating element wires in one direction it expects the sensor to react. The left hand plot shows no change in the LAMBDA when the current goes positive. The right had plot shows the LAMBDA goes way high (close to 1.99) when the current goes positive. Based on the lack of expected response it's obvious the ECU can make the judgement call that something is off and throw the P1172 fault. Moreover I think it can know that some idiot (myself) has tried to put an ordinary HO2S in place of the AFS and it might even be able to stumble along doing something useful with the information to improve the air/fuel ratio, but it is doing its job by throwing the error.
Long story short I was happy for the excuse to gain some experience and expertise with the OBDII port and the ISO9141-2 protocol. The sheer weight of obstacles thrown in the path of finding a cheap solution is remarkable. Sellers happily claiming their part is the one the car requires, google search NOT delivering results relevant to the underlying problem, and finally the OBDII tools available off the shelf not really designed to help in diagnosis. I can tell you from experience a laptop showing live plots of all the live data available from the OBDII port would be amazingly useful in diagnosing smog related problems. Someone could gain experience by observing the behavior of vehicles with everything working, then compare against a vehicle where something is broken.
Having gone to all this effort I'm a little irked that now I have to start over wiith the new problem of getting my 1994 Acura Integra to pass smog. It has been parked for a few years but the engine was fine when I parked it. Finally I'm getting it drivable again and I assumed it would pass smog with flying colors, but instead it was vomiting out so much CO (2.55% at 15mph and 2.76% at 25 mph) that it qualifies as a gross polluter. I changed the single HO2S and ran some injector cleaner through the engine and for the retest a month later those numbers dropped to 1.23% at 15mph and 1.22% at 25mph (less than half). So it's no longer a gross polluter but it still is too high on CO% (max is .54% at 15 mph and .53% at 25mph, I'm in California). I replaced the MAP sensor but I tested the original and new one myself and their output voltages as a function of vacuum are identical to the limit of my testing ability. So I'm unsure how to proceed other than more driving of the vehicle in the hopes that it will gradually improve enough to pass smog. I'd love to be able to measure the CO% myself somehow, since it's $75 for each attempt to pass the smog test...
Last edited by dashxdr; Jan 12, 2025 at 12:48 AM. Reason: Wanted to add the DENSO part number inscribed on the AFS
Old Jan 13, 2025
192?!? They used to go for 250!
emich
Feb 1, 2019 03:53 PM
tide55
Dec 19, 2013 11:37 PM
sekhonjatt
Jun 24, 2013 08:09 PM
BrickM
Sep 27, 2012 02:25 PM
4jacks
Nov 19, 2005 01:53 PM
