No speedo/tach, no gauges, no turn signals, no headlights
Old Apr 4, 2025
EStanley's Avatar
EStanley is an unknown quantity at this point
I'm rolling along, 75-80, and the speedo, tach, and gauges suddenly stop reading. needles drop to zero and bounce back up again.
This happens repeatedly, at shorter intervals, until the gauges are just zero'd. At the same time, the fan, signals, headlights, and I presume brake lights cease to work. The Recirc, AC, and defroster buttons would flicker together.
When I got off the highway, it was till running, but showing under 8volts. blipping the throttle made no difference to that at all. I made it home, and there was just enough to all up the windows. The starter laughed when I tried it. not even a click.
My first thought was a loose ground to the instruments, but that doesn't explain the low voltage, or the lack of power to the lights.
I checked the fuses without pulling any, and I didn't see any burned. I'll pul them and check tomorrow.
I'm left with alternator, or regulator.
The thing that puzzles me is that some things kept working at the same time as many did not
and just to make it al better? neither manual has any reference to the regulator. Like, say, where it is?
help?
IF it's just an alternator/regulator? that would be a blessing.
Old Apr 5, 2025
Colin42's Avatar
Re: No speedo/tach, no gauges, no turn signals, no headlights
Probably the alternator, don't cheap out. And make sure you tighten the bolts or you'll fry the computer.
Old Apr 5, 2025
EStanley's Avatar
alternator and regulator just tested good.
I'ma see if there'w enough battery for me to pull codes, and taking the alternator to NAPA for a second opinion.
It's also time to begin checking grounds.
IronFist
Sep 25, 2015 07:13 PM
stilllovemycivi
Dec 17, 2005 11:13 AM
MaddonE
Nov 15, 2002 12:51 PM
Hondasport01
Nov 4, 2002 06:53 PM
badcivic2002
Sep 15, 2002 04:33 PM
