Passenger window not working and came off regulator
Old Sep 1, 2022
johnh114532's Avatar
johnh114532 is an unknown quantity at this point
Motor works but no response from the switch.
The window simply fits into two 3/4" slots on the regulator - no bolts are attaching it. Does it need an adhesive to keep it in there?
Old Sep 2, 2022
BrotatoChip's Avatar
Super Moderator
Re: Passenger window not working and came off regulator
Check the driving door harness for broken wires. Specifically right where it bends every time the door is opened. A wire can break there and prevent the passenger window from working. Unless you have verified the switch itself is bad.
There should be two bolts in the center at the very bottom of the window.
Old Sep 2, 2022
Thanks, I will check the wiring where it bends. There are no bolts crimping down on those slots for the bottom of the window. It's just a slip fit - adhesive must have dried out.
Old Sep 3, 2022
Colin42's Avatar
There should be bolts, might be rolling around in the door
shhimsleepy
Electrical
20
Oct 4, 2023 04:32 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
SilverCiv05
Aug 2, 2013 12:14 AM
rthawley2
Feb 9, 2011 12:30 PM
boosterek7
Nov 20, 2006 03:36 AM
