Driver side window stopped working
I was installing my door speakers and I couldn't get my passenger window to work. I replaced the fuses and nothing, then realized I had pressed the switch to turn off the passenger window while putting the door back together. So, passenger works again, but now my driver side wont work? I tested the fuse, tried a few different new ones and it still won't work.
It worked fine before replacing the fuse. I've had the car for about two weeks, nothing ever seemed like it was shorting out or struggling before. The only thing was the switch was reversed (had to pull up to roll the window down)
Any ideas?
Any ideas?
Re: Driver side window stopped working
(Did the window have one-touch UP instead of down?)
I'll guess ..... see if their twist-n-tape wire splices came apart.
EXWisdom
Nov 5, 2001 10:24 PM
