ABS Fuse
Old Nov 30, 2021
eracgoat's Avatar
eracgoat is an unknown quantity at this point
ABS Fuse
Honda 2004 Civc Hybrid ( just brought it)
I notice the Brake and ASB dash lites where on. I checked under the hood and notice the fuse was blown. I went to replace it and as soon as I put it in it blow out again. Every time I tried to replace it it went out. I replace the fuse box and it did the same thing. I didn't see anything wrong with the wires near where it was plug in.
I got this car used and notice that was use to be an alarm in it that is still connected
Any suggestions
Old Nov 30, 2021
re: ABS Fuse
you have a short somewhere, find it
Old Nov 30, 2021
eracgoat's Avatar
re: ABS Fuse
Does The ASB wire go from the fuse box under the hood to the fuse box inside. I wanted to know the best why to chase the wire.
Old Nov 30, 2021
re: ABS Fuse
there is an SRS unit behind the dash in between - i think there are two modules
electrical issues are a pain, you need to chase the short
Old Nov 30, 2021
eracgoat's Avatar
Re: ABS Fuse
Would it just be easier to replace the plug with the wires all together
Old Nov 30, 2021
Re: ABS Fuse
depends where the short is located... It's common to have rodents chew the wires, colder now, warm engine, they get under and start a nest
Old Nov 30, 2021
eracgoat's Avatar
Re: ABS Fuse
thank you is there somewhere I can get the wiring diagram for the 2004 Honda civc hybrid
GERALD-OO-SEVEN
General 7th Gen
Nov 28, 2018 04:23 PM
Zeferint
16
Dec 14, 2012 11:16 AM
kbxer22
Apr 23, 2010 02:03 PM
Zzyzx
Auto X/Road Racing
27
May 11, 2005 09:16 AM
03civicdx
Aug 17, 2004 08:27 PM
