Abs Squealing, Abs Light On
Old Dec 21, 2006
kbxer22's Avatar
kbxer22 is an unknown quantity at this point
I have a 2002 CIVIC EX AUTOMATIC. The ABS pump noise that occurs after starting the car up and accelerating a bit is louder than normal. Sort of a grinding noise. It snowed here in Minnesota today and i had a chance to test my ABS out. The first time i tried it out, the ABS worked but it sounded a lot more pronounced than normal. There was the normal ABS sound plus an additional loud noise that also occurred. The second time i slammed on my brakes at a low speed the ABS pump made the noises plus a loud HIGH pitched squealing noise. I then turned the car off and waited 5 minutes. After 5 minutes was up i restarted the car and tested the ABS again from about 5 MPH. The same squealing noise happened but this time the squealing went on after i stopped the car and started driving again. Eventually afer 8 seconds the squealing stopped and the ABS light went on. The ABS no longer works and the ABS light is on. Does anyone have any suggestions on what this may be, how much it may cost, etc. Thank you so much to whoever can help me out. Happy Holidays!
Thanks,
Ryan
Old Apr 23, 2010
cerebrum3's Avatar
cerebrum3 is an unknown quantity at this point
Re: Abs Squealing, Abs Light On
The ABS light could be on due to various reasons, Best way to find out what is wron is to Get the ABS error code from the ECU and check it with the error code list for ABS errors.
There are two ways to find the error code
First you can attach a ABS scanner to the diagnostic socket, which is located near the driver.
Or you can check it yourself by connecting the pin 4 with the pin 9 of the diagnostic socket. Here is a video explaining the procedure
[YOUTUBE][/YOUTUBE] http://www.youtube.com/watch?v=tIBjIr9a42w
then check your code with honda specific abs codes
94-97 ABS CODES (thanks to JimBlake):
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
There's NO long flashes, it's all short flashes with short & long pauses in between.
Beginning in '98 there's a whole different ABS system, with a different list of codes.
98+ CODES (thanks to 2000GSRT)
11 - wheel senor (open/short to body ground/short to power) FR
13 - wheel senor (open/short to body ground/short to power) FL
15 - wheel senor (open/short to body ground/short to power) RR
17 - wheel senor (open/short to body ground/short to power) RL
12 - wheel senor (electrical noise/intermittent interuption) FR
14 - wheel senor (electrical noise/intermittent interuption) FL
16 - wheel senor (electrical noise/intermittent interuption) RR
18 - wheel senor (electrical noise/intermittent interuption) RL
21 - pulser FR
22 - pulser FL
23 - pulser RR
24 - pulser RL
31 - solenoid (short to body ground/short to wire) FR-IN
32 - solenoid (short to body ground/short to wire) FR-OUT
33 - solenoid (short to body ground/short to wire) FL-IN
34 - solenoid (short to body ground/short to wire) FL-OUT
35 - solenoid (short to body ground/short to wire) RR-IN
36 - solenoid (short to body ground/short to wire) RR-OUT
37 - solenoid (short to body ground/short to wire) RL-IN
38 - solenoid (short to body ground/short to wire) RL-OUT
41 - wheel lock FR
42 - wheel lock FL
43 - wheel lock RR
44 - wheel lock RL
51 - motor lock
52 - motor stuck OFF
53 - motor stuck ON
54 - fail-safe relay
61 - ignition voltage
62 - ignition voltage
71 - different diameter tire
81 - central processing unti (CPU)
conspiracy90
Jun 7, 2023 01:01 PM
marciano117
Jun 25, 2015 09:06 PM
Wraithen
Jun 7, 2015 01:48 PM
Fudman
Jun 2, 2015 01:26 PM
tattedlariat
Apr 12, 2015 07:55 PM
