Master door lock switch doesn't lock doors when keys are in ignition
Old Sep 1, 2021
southofhell's Avatar
southofhell is an unknown quantity at this point
My 04 EX Sedan's master door lock switch functions as expected without a key in the ignition. However, when the key is inserted, the switch will unlock all doors when pressed up, but will not lock all doors when pressed down (nothing occurs). Because the behavior changes depending on key insertion, I'm wondering if this is a feature of this car, or is it something that I have to troubleshoot?
Old Sep 1, 2021
CraigW's Avatar
Re: Master door lock switch doesn't lock doors when keys are in ignition
Normal Operation
Old Sep 1, 2021
Driver door open: no lock
Driver door closed: can lock
Owners manual should cover it
Old Sep 1, 2021
The intent is to make it difficult to accidentally lock your keys in the car. You gotta make extra mistakes to lock the keys inside.
Old Sep 1, 2021
Makes sense. I must've had a door open while I was testing the switch. Thanks guys.
Kigoral
Feb 8, 2016 11:34 PM
MB00SI
Apr 6, 2015 05:56 PM
acmrrll
Feb 21, 2015 02:12 PM
ThatDude
Aug 23, 2012 05:55 AM
amberlynette
Aug 6, 2009 05:27 PM
