alarm remote 2002 question
Old Oct 29, 2020
F22C4me's Avatar
F22C4me is an unknown quantity at this point
Hello All,
Don't come on here much because the whip runs pretty good. However, it recently does strange things with the alarm/lock remote when trying to use the fob. Strange as in the door lock indicator on the drivers side will not go down all the way when pressing the button on the fob, rendering the alarm useless. Locking feature works fine when key is used. Any ideas?
THANKS,
Chuck
Old Oct 29, 2020
CraigW's Avatar
Re: alarm remote 2002 question
Try working the locks several times..... lock/unlock, then see if the lock works normal (for a short time)
Could indicate weak acuator. Pretty common on 7th gens.
Old Oct 29, 2020
F22C4me's Avatar
Thank you Craig. I'll try it but I bet it's the actuator.
Old Nov 12, 2020
F22C4me's Avatar
Hey All,
I replaced the actuator but still a no go. My father believes it is something in the wiring passing through the dash and going into the door. Unbelievable bs as I may have to leave it be and classify this as "unsolvable".
Old Nov 12, 2020
Colin42's Avatar
Check the wires in the door harness, they like to break where they flex in the door jamb
Old Nov 13, 2020
F22C4me's Avatar
Ill see what it looks like in there. If its not viewable in the rubber boot I'm done.
Old Nov 13, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
I have had a couple of instances of wire repair in the driver's door hinge area but for non-operable power windows. It is a common repair on these vehicles as they age.
Old Nov 13, 2020
Colin42's Avatar
It breaks in the rubber boot
pixie289
Nov 12, 2015 05:20 PM
GSmith215
Aug 27, 2011 10:11 AM
cmcculloh
Apr 6, 2011 06:50 AM
blackBDMcivicLX
Jun 3, 2006 11:06 AM
pnoyster2k1cvic
Feb 16, 2005 12:28 PM
