2003 Civic coupe Ignition and engine
Old Jun 30, 2020
mJohnson's Avatar
mJohnson is an unknown quantity at this point
I’d appreciate if anyone has an answer on this. Part of me believes my starter is what’s bad. After trying to turn the engine over, nothing happens, engine won’t crank whatsoever. And when I try to take my key out of the ignition, it gets stuck. Can’t move the vehicle out of park either.
Old Jun 30, 2020
Re: 2003 Civic coupe Ignition and engine
Sounds like what might happen if a rodent chews off the wires for TPS/starter/range switch.
Probably has a pile of fault codes too.
Old Jul 2, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
A defective brake pedal position switch can cause the car not to crank. Its the little plunger switch that hits a pad on the brake pedal.
Old Jul 2, 2020
mJohnson's Avatar
would that also prevent the gear shift lever to not allow you to shift out of park? Cause that’s one of my issues too. But I’m not sure if that would have anything to do with the key getting locked in the ignition
Old Jul 2, 2020
NDNV's Avatar
Yessir!
Old Jul 2, 2020
mJohnson's Avatar
Well I wish I could say that was the issue, but I checked it and it was fine. I’m not entirely sure what else to do
Aidizz
Aug 16, 2018 10:15 AM
krutch52
Nov 27, 2015 06:32 PM
tg5398
Oct 10, 2009 11:38 AM
STang57
Jul 15, 2002 04:56 AM
