OBD2 Port & electrical problems
Old Aug 28, 2019
mJohnson's Avatar
mJohnson is an unknown quantity at this point
Okay so I have a 2002 civic lx 5 speed. I tried to reset an abs light. Sure enough I was able to reset the light. But the method was to put a wire in pin holes 4&9 in the OBD port... and I’m pretty sure I might’ve screwed up at first I might’ve accidentally put the wire in holes 5 and 18, so I was totally flip flopped, now in exchange my radio doesn’t work. As well as power locks, dash&cluster illumination lights, and dome light doesn’t work unless the key is on. Also my door chime doesn’t beep anymore. I’m so confused and have no clue what to do. Some help would be greatly appreciated. Checked all my fuses and all of them are fine.
Old Aug 29, 2019
BrotatoChip's Avatar
Super Moderator
Re: OBD2 Port & electrical problems
Pin 5 is ground and pin 16 I believe is battery, that would obviously cause a short. Check fuse number 9 (10 amp) in the under-hood fuse box.
Old Aug 29, 2019
mJohnson's Avatar
Thank you i could’ve sworn I checked but I guess it’s JSU the one of those fuses you miss every now and then lol
civic1993driver
Jun 16, 2014 01:44 PM
RcHaN08
Mar 23, 2006 12:06 AM
EnProceso
North Cali
Jun 28, 2003 10:19 PM
EnProceso
Jun 28, 2003 10:10 PM
spoiledsteph
Jan 31, 2003 01:57 AM
