blown fuse?
Old Mar 22, 2006
RcHaN08's Avatar
RcHaN08 is an unknown quantity at this point
blown fuse?
hello friends,
i tried searching for this but couldnt fine the answer i was looking for. one day my amp stopped working. i noticed when i didnt hear any bass. anyways, my headunit still works but my amp light doesnt work. so i thought it was my amp fuses and they looked blown out so i replaced them. so i replaced them with the same capacity and color one at a time. 1 sec later i see a spark from the fuse hole and see smoke coming out of it so i took out the fuse and it was blown again. so i did it again then it smoked up again. does any1 know whats wrong and what i can do? thanks fellas.
Old Mar 22, 2006
Kingnine's Avatar
Kingnine is an unknown quantity at this point
sounds like you have a grounded power wire? there is a fuse between the amp and the battery right?
Old Mar 22, 2006
RcHaN08's Avatar
yes there is and i changed that too but didnt do anything so i put it back to the orignal fuse.
Old Mar 22, 2006
Kingnine's Avatar
sounds to me like a blown amp, but i'm not an expert. heres a way to check. take the amp out. take two wires to the positive battery terminal, then one to the negative. put one positive to the battery on the amp and one to the remote turn on on the amp. put the negative from the battery to the negative on the amp. if it works then you have a wiring problem. if not then it is probably something wrong with the amp. just to be safe i would try to rig up a fuse in between the power wire on the battery to the terminal on the amp for power.
Old Mar 22, 2006
RcHaN08's Avatar
ok ill try that tomorrow. how would i rig up a fuse in between the power wire on the battery to the terminal on the amp for power? u mean when i take the amp out and test to see if its not blown?
Old Mar 22, 2006
Kingnine's Avatar
its just a safety precaution. you can take a couple of female spade connectors and attach wires to them then slide the connectors onto a standard fuse of whatever amperage. its a little jerry rigged but should work fine without rigging in a full fuse holder type gizmo.
Old Mar 22, 2006
Kingnine's Avatar
Old Mar 22, 2006
Kingnine's Avatar
Old Mar 22, 2006
catalin's Avatar
catalin is an unknown quantity at this point
You copuld always disconnect the power wire at the amplifier and insulate it. Replace the fuse at the battery, if it blows again then it's the wiring that's at fault.
If it doesn't then it's most likely the amplifier.
Old Mar 22, 2006
RcHaN08's Avatar
so if i disconnect the power wire at the amp. how do i insulate it? do i just plug the power back to the amp and if the fuse blows then its the amp?
Old Mar 22, 2006
catalin's Avatar
Insulate it, you know cover it up with tape or something. Just make sure it doesn't touch metal while you put the fuse in again.
Old Mar 22, 2006
wicked8932's Avatar
wicked8932 is an unknown quantity at this point
maybe you jut need a higher ampage fuse?
Old Mar 23, 2006
RcHaN08's Avatar
oh ok well i just replaced the fuse with the same fuse that i was using same color and same ampage. but thanks catalin and kingnine ill do that stuff tomorrow. but if any1 else knows whats wrong let me know thanks.
Bman2212
Sep 2, 2015 11:49 AM
Jwzy
Aug 24, 2015 09:35 PM
cyc
Jul 22, 2015 01:14 PM
Civic65
Jul 19, 2015 10:13 AM
ZILLA
Jul 5, 2015 05:24 PM
