1993 Dome Light (Help Needed)
Old Jun 15, 2014
civic1993driver's Avatar
civic1993driver is an unknown quantity at this point
Exclamation 1993 Dome Light (Help Needed)
Dome light doesn't work,
I took out the housing and switch, disconnected the connectors.
Put a test light and volt meter to the leads, I got nothing.
I checked all the fuses under the dash(I don't have a diagram nor could I
find one for that year and model) so I checked all of them.
Ide like to know which fuse number it is so I can see if there is a short in between.
I am now here asking you folk,
What would you do?
Where can I get a fuse diagram?
Thank You,
Civic1993Driver
Old Jun 15, 2014
Re: 1993 Dome Light (Help Needed)
Dash fuse box
fuse #3
7.5 amp
Got ground?
Old Jun 16, 2014
Yes #3 7.5 amp fuse is in place and functional(even checked continuity).
So that is a good question, does anyone know where the ground for the dome light is grounded? I feel like this is the most likely culprit.
And since there is not a full circuit should I check continuity dome neg to battery neg also the dome pos to battery pos?
Old Jun 16, 2014
How should I diagnose this issue?
Old Jun 16, 2014
Each of the jamb switches. And maybe a mounting screw.
How else will you know which side is missing?
Civicman92296
Apr 23, 2015 09:22 PM
twtron
Apr 17, 2015 12:09 AM
Myredjonda
Apr 14, 2015 07:00 PM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
