Smoke & Burn't Electrical Smell under Steering Column
Old Apr 23, 2007
Ricerockt's Avatar
Ricerockt is an unknown quantity at this point
Here is a wierd one for you: On the way to work today, about 15 minutes into my drive, my 01 EX coupe starting smelling like burned electrical components/wiring from under the steering column. I even saw a little bit of smoke. The left-side of the top steering column cover was also warm to the touch.
Through searching, I found a few posts on a headlight wiring replacement recall. Do you guys thing that is the problem? I am the only owner of the car with 100k on it and have never taken it in to the stealer for any recalls.
Old Apr 23, 2007
CraigW's Avatar
Re: Smoke & Burn't Electrical Smell under Steering Column
It would only happen if the headlights were on at the time. (low-beams) I think all of the 01s were affected. The column covers are very tough to remove without breaking the latches on the top cover. I would let the dealer do all the work.
Old Apr 23, 2007
Ricerockt's Avatar
Ya, the low-beams were on at the time.
I'll call the dealer and have them check it out.
Old Apr 30, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I wouldnt continue to drive it like that...
WaryDriver
23
Jul 22, 2015 07:18 PM
Jul 12, 2015 11:54 AM
jferristx
Jul 8, 2015 10:09 PM
Causemo
Jul 4, 2015 07:11 AM
